temccarthy1's avatar
temccarthy1
Need advice on this winterization detail
I winterized my new 2014 Bullet TT last year after it's first season in 2015 successfully by using pink antifreeze that I pumped through system with a winterizing hand pump connected to the city water hookup. I had never used the fresh water tank my first year and there was no water in it. This year, I am getting ready to winterize and I did use the fresh water tank a few times as well as the city water hookup on other occasions. My question is even though I have emptied the tank and the low water drain for my fresh water tank, do I need to do anything to that tank and the water pump since I plan to again pump pink stuff through my city water hookup to all the faucets, toilet, shower and outside shower as I did last year. Having used the fresh water tank and water pump this year but currently tank is empty, is there any water still in the pump that could cause damage even though tank is empty? I am planning to winterize just through my city water hookup and want to insure that there is not another step needed for my fresh water tank and pump. Thanks for your advice!
