NRALIFR
Jul 01, 2016Explorer
Need Help w/2016 F450 Charging System
I'm not sure if this should be in Tow Vehicles or Tech Issues.
I'm in the process of installing a heavy-duty battery charging circuit for the truck camper battery on my new truck. I've done this on two previous trucks, and was able to improve the charging voltage and current going to the camper battery enough that I could run the fridge in AC mode from an inverter while driving, and the battery would maintain a decent state of charge.
I've worked on the truck the last three evenings, and I'm close to being done with the "truck side" of the new TC charge circuit and plugs. I've got the isolation solenoid connected to upfitter switch #4, so I can turn it on and off now.
When I started this, I had planned to connect the +12v wire directly to the alternator, like I had done on my last two trucks. But, after studying how the batteries and alternator are connected, I'm hesitant to do that. At least, until I have time to get more info about the way things work. It appears that the two batteries and the alternator all connect to this device on the passenger side of the engine compartment.
As near as I can tell, the alternator output, and the positive cable from both batteries are connected to this. Also, that black square device on top looks like a shunt. After seeing this, I'm thinking connecting a load directly to the alternator might not be a good idea. In the image below, it appears there is an empty position on the RH end of the bus bar that I might be able to connect to, if I had the right kind of connector. Any thoughts on this?
So, until I can figure this out, I connected a red cable to the positive post of BOTH batteries, and brought them together on the "input" side of the CB. Probably not ideal, but it should work reasonably well. The wire in split loom going across the top of the radiator is mine. I've tried to run my wires so that they won't make the truck harder to service.
I've tried to find a schematic for the 2016 SD's in the bodybuiders guide, but there doesn't appear to be one for the 2016 yet. The 2015 version seems to cover the E-series vans charging and starting schematic in great detail, but not the SD's. I'm at a loss, and feel a little out of my comfort-zone right now. The engine compartment is so packed on this truck it's nearly impossible to tell "point-to-point" where the heavy gauge wires are going.
For now, I think I've got it connected in a "safe" manner. I'd like to know if there's a better way from a functional standpoint.
