Me Again wrote:
IdaD wrote:
 and the front pucks mount the same as they do on the 3500.
If the front pucks mounted the same, then the bed would have to be lifted. It has been posted that the 2500 bed does NOT have to be lifted.
Chris
Go look at the actual parts and stop relying on hearsay.  On the 3500 the two side plates are welded on the frame rail, on the 2500 the plates come with the mounting kit and are bolted on the frame rail.  The puck mounts to the plates in the same manner on both on top of the frame rail.
You're missing the larger point that was made because you're too busy nitpicking at immaterial issues.
