TrekkerB's avatar
TrekkerB
Need Hitch Recommendation
We are hoping to purchase a new travel trailer in the near future and just wanted to get some advice concerning the tow-ability of our proposed rig and a hitch recommendation.
First the details, our tow vehicle is a 2013 Chevy Express 3500 with the standard wheelbase of 135", it has the 6.0L combined with the 6 speed transmission and the 3.42 rear end. Curb weight is 6087#'s with a GVWR of 9600. Payload is 3513 according to our VIN. Tow rating is 9700 with a GCWR of 16000. Our van has a Curt V5 receiver and is wired with a Prodigy P3 brake controller.
We are looking at a Jayco 28BHBE that has a dry weight of between 6600-7200# depending on how it is optioned out. Camper GVWR is 9250, but I consider that to be mostly irrelevant as there's no way that we will add 2000-2500#'s of gear. I'm thinking that loaded the camper weight is going to be in the 7600-8700 range depending on how it is equipped/loaded, etc. If so, I should fall within my weight ratings by my calculations (including about 625#'s passenger weight).
I've towed my father's TT (Jayco 26BH) with little difficulty using a WD/dual friction bar setup. However, it is several feet shorter and at least a 2000#'s lighter.
My greatest concern is trailer length in relation to tow vehicle wheelbase. The 28BHBE is 33.5' long and my wheelbase, as mentioned, is only 135".
So, I'm wondering:
1) Do my weight calculations look good?
2) How will the 6.0L handle the extra weight?
3) Given the length/wheelbase combo should I step up to a premium hitch (Hensley, etc.) or would something like a Reese Dual cam be sufficient? Please note that I'm not trying to start a debate on the merits of one hitch versus the other, but am looking for advice given my unique situation. Thanks!
  • TrekkerB wrote:
    Out of curiosity, what air pressure do you run in the front tires?
    I run my van at 60 psi front. Mine calls for 55 however I have about 400 pounds of steel bumper and winch on the front. I get better braking traction at 50 psi and it rides smoother, but at that psi I can feel the tires roll onto the sidewalls when cornering hard, and they also wear like they're under-inflated.
    Since your van is much lighter on the front end, I'm not surprised that over-inflating the front tires made it feel worse, since you're decreasing the contact patch as the higher psi.
  • Bought gas for $1.39 yesterday! My last trip towing ~5,000#'s I got about 9.5mpg :-). The van actually (thankfully) does really well...I get about 18 on the highway empty.
  • The combination should work, but you will really appreciate it if gasoline stays under $2.00/gallon. Figure on 7 mpg, or possibly a little less.
  • Also, just checked...my van doesn't have the recall notice :), but thanks for drawing it to my attention.
  • Out of curiosity, what air pressure do you run in the front tires? My van calls for 50psi. I tried running 55psi and had a moment while towing when the front end felt light and tried to "float" on me. This was with the WD setup tweaked to where I only had about 1/2" of sag in the rear and the front was about the same as unloaded. Reduced the front to 50psi and didn't have any further trouble. Seems odd to me that 5psi could make that kind of difference.
  • Oh, and to your original question.... I'm super happy with my Blue Ox Sway Pro! It rides better than other WD hitches and doesn't make any noises. That's what I'm using on my Creekside, which is 38' overall with 4 slide-outs. It works great, even with a 2nd trailer behind that.
  • This is a copy that other owners received. Be sure to verify yours is not affected, but I believe some 2013s were part of it.
  • Thanks and I agree...the OEM shocks are garbage. I replaced them a few weeks ago with Bilstein's! After removing, I compressed the old shocks by hand and they never expanded...wore out. The Bilstein's have definitely helped with front end bounce and look forward to trying them out while towing.
  • I think you're good on payload. Even with the short wheelbase your van should be stable. I would highly recommend upgrading to Bilstein shocks. Then OEM shocks are garbage, and you'll really feel that with a heavier trailer.
    I think you'll be really close on combined weight. The dry weight doesn't include "options" such as:
    Customer Value Package (Mandatory)
    13500 BTU Central Air, 30 lb. LP Bottle w/ Cover (2), 6 Gal. Gas/Electric DSI Water Heater (10 Gallon in 38BHDS & 38FDDS), 8 cu. ft. Refrigerator (Residential Fridge in 38BHDS & 38FDDS), Bath Skylight, Bathroom Vent, Bedspread, Cable/Satellite TV Hookup, Digital TV Antenna, Microwave, Outside Shower, Oven, Power Tongue Jack, Spare Tire, Tub Surround, Water Heater Bypass
    I really think you'll probably end up closer to the trailer's GVWR than you expect.
    Power wise you'll be ok. But the Express is cooling limited on both the engine and transmission. The Class C owners have discovered Hayden makes a better fan clutch that keeps the engine cool. GM has a recall out for the transmission which reduces torque converter lockup so it won't burn up the clutch, but that will probably make it run hotter overall.
About Travel Trailer Group
44,030 PostsLatest Activity: May 11, 2025
