cindy520's avatar
cindy520
Need info for Tundra and Lance 650.
I am trying to find information about purchasing a truck camper for a new 2016 Toyota Tundra Crew Cab with a 5 + foot bed. I am looking at a Lance 650 and just wondering if it is to heavy?I know the Lance company says it is okay but I am wondering if anyone has tried it out.
Would I have to make sure I have heavier stronger tires, maybe a air bags things for the weight?
I can't seem to find anything on this site or anywhere else.
Any information would be greatly appreciated.
Cindy
  • Cindy,
    Some numbers are in order.
    2016 Tundra CrewMax, I'm assuming 4x4 weighs either (in pounds)
    5570, 5645, 5670, 5690 depending.
    The GVWR, Gross Vehicle Weight Rating is: 7000 to 7200 pounds.
    That leaves the payload capacity at 1430 to 1555 pounds.
    I see no heavy duty factory option as to drive train, suspension, brakes, or tires.
    You have these options:
    1. Get a larger, higher GVWR truck. or,
    2. Get the smallest, lightest pop-up camper you can find and still be overloaded. The Lance 650 on a Tundra would be living on the edge alright.
    I wish it weren't so. I like the Tundra platform, but it's made to look good, with good power and have a cushy empty ride.
    Thousands of potential TC buyers have faced your predicament before you. Some even understood the paradigm shift.
    jefe
  • Tundra crewmax trucks only have about 1300lbs of payload maximum. Not nearly enough for that camper and passengers. Unfortunately this will be the case for most 1/2 ton trucks. You'll need a 3/4 ton minimum.
  • Depends if you want to be by the numbers on everything or not.
    E load tires and something to help the suspension will carry a 650 ok. Not ideal but not a deal breaker imo.
  • If you haven't already discovered it, Lance Campers have a very active owners association and one of the discussion forums online is Truck Camper Chatter. I think you'll find them very helpful on almost any topic. Here's the link:
    Lance Truck Camper Chatter
  • Toyota Tundra Crew Cab with a 5 + foot bed? The extra short bed is a very poor choice for a truck camper. I doubt you could achieve proper axle weight and center of gravity with the 650.
  • Lance shows that camper at 1900 pounds wet. Add about 500-1000 pounds for your stuff.
    The tundra I believe has a cargo load rating of about 1500-2000 pounds.
