Need new mattress
skyflyer
Time for a new mattress but do I get a memory foam or standard. Why did you choose one over the other?
2016 Grey Wolf 26RR
2016 chevy Silverado
13 REPLIES 13
tomman58
tmm2good wrote:
If you like what you have at home, get the same thing.
Absolutely! If you don't sleep on foam then why in your RV? I spent 1000 bucks on our old TT to have the mattress shortened to fit. It was worth it. This one we got lucky and got a great mattress that fit.
2015 GMC D/A, CC 4x4/ Z71 ,3.73,IBC SLT+
2018 Jayco 338RETS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
We have a granite fireplace hearth! Love to be a little different.
tmm2good
18 GD Momentum 376
13 GMC Denali Dually D/A
Motorcycles / ATV's
rbpru
Like many our "Queen" mattress was on the small side. It was also quite uncomfortable. We purchased one of those 4" thick egg carton type foam tops. It has served us fine.
Unfortunately, describing a good mattress is like describing a good beer, it is different for everyone.
About the only thing most folk will agree on is, the mattress that come with the TT is rather poor.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
2012Coleman
Search for RV Mattress on Overstock.com
2018 RAM 3500 Big Horn CTD
sdianel_-acct_c
we bought www.bedinabox.com at the recommendation of some members of this forum. We love it! We bought the PacBed Original. 11" deep with gel. They make a short Queen that fit perfectly. It was shipped to us in a box. Weighs about 87 pounds. Remove the old mattress, bring the box inside and put on bed platform, carefully unwrap the new one (don't cut the mattress), and voila! instant bed. We've had it about 3 years. Benefits: firm but no pressure points, gel makes it cooler, don't feel the other person when they toss and turn or get in or out of bed, retains it's shape even on edges. Well worth it and great 10 year warranty. You can try it for 60 days and if you don't like it they will pay to pick it up.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
PershingD
The very first modification was to order a short queen memory foam from Amazon. Its warmer than I prefer, but my wife has RA in her hips and it is very comfortable for her. I'll adjust if it means she feels better while we're out.
David Pershing
Gayle-DW
Alex-DS
Jesse-DS
Nikki-DD
Justin - DS
1997 Dodge Ram 3500 8.0L V-10
2017 Zinger 27RL
TurnThePage
I'm an inner spring mattress guy all the way. Even the foam ones that don't get hot are too hot for me.
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
Community Alumni
Not applicable
You can find spring and foam mattresses in equivalent comfort levels. If you have one of the non standard mattress sizes (i.e short queen) then foam mattresses are nice because you can easily cut them down so you'll have more options. With spring mattresses you're limited to the ones that fit. Foam mattresses are normally easy to maneuver since they usually come in small vacuum packed boxes. Just drop the box on the bed, cut it open, and the mattress pops out.
As far as longevity, it depends on how you use it. If you're using the bed occasionally then longevity would be a wash between the two. The mattress won't see enough use to see a difference. If you're using it almost daily then I would lean more towards foam. Spring mattresses tend to show signs of wear only after a few years of daily use. Tomman58 mentioned breathability, but this isn't a problem with modern multilayered mattresses. A lot of foam mattresses are built with air chamber layers to allow heat to pass through.
We went through the whole foam vs spring thing. After lots of research and laying on tons of mattresses, foam ended up winning out and we won't be going back to spring. The foam mattress we bought ended up being better than any other spring mattress we've ever had.
Merrykalia
We had a TempurPedic in our house and LOVED it. Didn't want to spend $2500 for a mattress in our RV, but bought an 8" Spa Sensations Gel Memory Foam one from Walmart for less than $200. It was/is GREAT. When our TempurPedic died, we purchased the 10" Spa Sensations one for our house. It's still in great condition and like tomman58, we spend 100+ days in our RV each year.
2017 Ford F350 Crew Cab 6.7L 4x4 DRW
tomman58
Unlike many we use or TT 5 to 6 months a year so the mattress is in play unless you want a bad back. We bought ours at a mattress store. It is full size queen (on our last trailer it was a king and we had it shorten a few inches to fit) it is about 10" longer than the plywood base. When we bring in that slide I raise the plywood and then drop it down when in. The end of the mattress lays on on the dresser at the end. Works for us and the real mattress is very good , I hate foam and those products. This mattress can breathe and even in summer is cool.
2018 Jayco 338RETS
2 Trek bikes
Honda EU2000i
WayneAt63044
Ditto what Jay Pat said. A regular queen can be cut to a short queen size with a serrated knife. Ordered our 8" thru Sams Club for $245 5 years ago. My wife is short and has a bit of an issue climbing up on 8"/ maybe 6" is enough.
2012 Forest River V-Cross Vibe 826VFK
pulled by 2009 Ram 1500 Quad Cab Hemi
Jay_Pat
I purchased memory foam because it is easy to cut to fit the plywood foundation in the rv. Very easy to cut with an electric meat carving knife.
Feels like a regular mattress to me.
Pat
2010 Ford F-350 SRW
2021 Grand Design Reflection 315
DutchmenSport
We use the same one we have in our house. Except our house is a King and the camper is Queen. It's a Serta!
