panamacamper1
Jul 12, 2012Explorer
Need new tires ALREADY!
I puchased a new Shadow Cruiser 280qbs, it has 205/75/14 load C tires.
I have maybe 1000 miles on them and I always check the tire preasure before trips.
My unit (unloaded) is around 5,200lbs and (loaded) around 6,600lbs. I know you have to run tires at max psi(50) to get full use of 6 ply on tires. It has double axles and each axle is measured at 4,555lbs.
I need to take her in and see if the axles are out of allignment or bent. Is this under warrentee if I am still with-in a year of purchase?
What tires would you recommend?
UPDATE: This is after I did the rotation of the two rear axle tires. Remember I have maybe 700 to 800 miles on these tires. TT was brand new.
Bald on the inside (original left rear axle tire)
Bald on the inside (same tire) picture the other tire bald on the outside.
tread burned off the outside edge, this is from the tire before i rotated them, so it is bald on the outside
These are the tires that I have
