Need tires on my Ram Tow Vehicle.
Spade_Cooley
I have a 2016 Ram 1500 with Hemi that is 4X4. I love the truck and thus far I've towed my older trailer with the stock Wranglers. My new TT is a Rockport Ultralite at around 6500 LBS. The truck tire size is P275/60R20. I've been looking at Coopers, General Grabbers and Hankook. So far so good on towing with the old Wranglers but I'm going to take a long trip and want a decent set. Do I need something special to tow or will any LT tire work? What do you like?
23 REPLIES 23
bnardini
I like Michelin Defender LTX. I'm on my 4th set and haven't had so much as a slow leak. They are also load range E.
Bill & Lori Nardini finally on the road!
2008 Tundra SR5 doublecab
2009 Jayco 31 RKS G2
azrving
Oem Firestone Transforce went 40k. Michelin Defender LTX went 67k
GrandpaKip
I have been using Cooper tires for the last few years and have been happy with them.
Continentals in the same size as yours came on our new truck.
I usually have about 1100-1200 pounds of cargo and tongue weight.
So far, the P tires have been fine. I air them to 45 psi when towing and 35 psi when not.
When they need replacing, I will probably go with Cooper LTs.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Grit_dog
Navigator
Navigator
GordonThree wrote:
I was considering the same, switching my grocery getter from 20 inch passenger car tires to 18 inch truck tires (range E)
I'm not a fan of how these factory low profile 20" tires handle my trailer, and with a max sidewall of only 51 psi, they're not cut out for towing.
Both 18 and 20 inch rims are a factory option, so the computer must have an electronic switch somewhere to reprogram the wheel size?
There’s plenty of 65psi tires in your size.
Not against E load tires, but you’re not likely to carry enough Weight to actually need an E load tire.
20s are great for towing. Less sidewall = less sidewall flex.
time2roll
Wrangler Duratrac or All-Terrain with Kevlar is my choice. Not all Wrangler are the same.
bguy
Hankook makes an LT 10 ply in the stock size. I'm waiting for a set to come in for my 11 Ram 1500.
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
Campinfan
I had Coopers on my last truck and will need new tires next summer. I will go with Coopers again. I think they were the Discover ATP. Will buy them again. Aggressive tread but super quiet on the road. Lasted a long time on my old F250.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
GordonThree
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
dodge_guy
I ran Generals on my Excursion when I had it. They wore good and I never had an issue. I would definitely recommend LT tires if you can find them in a 20" size.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
