Need to hire welder - help!
chracatoa
So I need to do some spot/tack welding on my hitch. Any ideas where/how can I find these kind of professionals that do the job - and for a reasonable price?
I found just one - minimum quote is $400, seems too expensive.
A friend of mine told me we could take a class together. I'm all for learning new things but I'll be driving this thing and I don't want to do a bad job. I know nothing of welding. Would you do it?
Thanks!
2011 Toyota Sequoia Platinum 4WD 5.7L V8 (next one will be a 3/4, someday)
2012 Jayco Flight Swift 267BHS (5963lbs dry, 6850 wet)
Propride hitch (I had a Reese dual cam round bar WDH for 4 months)
25 REPLIES 25
jaycocreek
Know need for a welder if yours are like this.
Lance 9.6
400 watts solar mounted/200 watts portable
500ah Lifep04
kalynzoo
Many U-Haul locations do hitch work, many muffler shops will do spot welding, just a few ideas. I would not do it myself, even though it is supposed to be an easy to learn skill (my neighbor welds) if the hitch fails it could make a mess.
DutchmenSport
If you take a class, then you have to purchase all the welding equipment. I'm sure that will cost more than $400.
Check small engine repair shops, lawn mower repair shops, Echo (weed eater) shops. I had a hitch installed on my pop-up by an lawn mower shop about 15 years ago.
Huntindog
You could bolt the jacks on. This is not what one would consider to be a critical weld. The jacks won't be stressing the weld when in use.
But, it would be over head welding, which I personally find hard to do.
Welding itself isn't all that hard, and the purchase of the equiptment to do it has paid me back s of times over.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
westend
Look in the Yellow pages for welding services, there is likely someone close to you. It will end up costing you many more $$$ DIY'ing if you don't own a decent welder, than having it done by a pro.
BTW, those harbor freight wire feed welders are ok for doing small repairs around the house, they're not for any kind of serious welding.
'03 F-250 4x4 CC
chracatoa
Nope, Redmond.
path1
Send me PM and I'll give you info on guy I use that has been in business many years. $400 sounds like a lot for
P.S. I do have a welder but welding is like an art, you don't just get good at it from a couple times. So I take important welding jobs to him.
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
chracatoa
I want to weld the jacks to the frame. What do you mean by machine shops? Any suggestions?
camp-n-family
What exactly needs to be welded? The hitch head? Receiver? For $400 you could buy a new one of those.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
falconbrother
I would do my own and I would do some stress test on it before I took it out on the highway. With welding a lot has to do with the equipment you use. Personally, I have made some decent welds with a cheap Harbor Freight MIG welder but, for something like that I would rather use a stick welder and Lincoln rods. Welding isn't hard. It's more of an art. It takes time and practice to get good at it.
If you have never welded I would not trust a rookie weld to pull thousands of pounds down the interstate.
TPUC
You can find a better deal than $400 that's crazy. Check with local machine shops. don't weld it yourself welding is a skill not learned in a few classes.
2012 Nissan Titan Pro 4X
2014 Cruiser Aire
