New and looking for a generator
GravelRider
Hello everyone. I'm buying my first travel trailer, a Forest River Cherokee Wolf Pup 16BHS. I am planning to do a lot of boondocking, and I want a generator. I want a small portable generator, but I don't want to go too small. I'm thinking I can comfortably do a 3000 watt generator, but I'd like to get some opinions of experienced RVers.
The travel trailer has a 13,500 BTU AC unit, a microwave, and I think everything else will be DC. We'll be running the normal lights, water pumps, etc., charging a couple phones and tablets, and may add a DC television as well. That's about it. I'm completely fine with shutting off the AC while using the microwave.
What size generator do I need?
And any suggestions on quiet cheap generators? (quiet being more important than cheap, but I'd prefer not to spend a ton)
Thanks everyone.
79 REPLIES 79
GravelRider
Thanks for the replies. I've been looking at the Honda generators, which are nice, but PRICEY. I'm not saying they're out of the question, but how does this Champion match up? https://www.amazon.com/Champion-3100-Watt-Portable-Inverter-Generator/dp/B00JZQUSAC/ref=sr_1_10?dchild=1&keywords=champion+portable+generator&qid=1589425137&s=lawn-garden&sr=1-10
sh4717
Go with the Honda 2200w generator. I have your same setup and it runs the air and microwave (separately) just fine.
Scott
2019 Northwood Nash 24M
2018 Ram Ecodiesel
TomG2
There are hundreds of threads on this subject and you will get repeats from the regulars telling you that only red generators are good and yellow generators are evil.
The best "What generator"? response is , "Go camping where you don't need an air conditioner and spend the money on something else." I realize that we all love our generators but people can have more fun camping than sitting in an air conditioned box and popping microwave popcorn. Enjoy yourself.
ktmrfs
3000 watt likely will do what you want, but may be heavier than you want to handle.
A 2000W inverter generator is likely to have problems starting the AC unit, especially at higher altitude. But it will be quite and easy to carry around. Add a micro air easy start to the AC and the 2000/2200W generator will likely do what you want.
Now quiet & cheap are somewhat mutually exclusive. PLEASE do NOT buy an open frame cheap generator. Spend some money on a quiet inverter generator. honda yamaha and champion have some nice decent quality quiet generators in the 2000-3000W range.
We boondock a lot, have a 13,500 BTU AC unit, an 1000W microwave and have a single honda 2200 W generator. My brother has the same. The AC units have the micro air easy start installed. Both of us consistently run the AC units at altitude approaching 7000ft with zip problems starting or running the AC. That said a honda 2000, or yamaha 2000 will eventually (20 minutes or so) overload at altitude above about 4500ft.
Just can't run the AC AND microwave at the same time, but a 3000W wouldn't let you run both at the same time either.
2011 Keystone Outback 295RE
Lwiddis
If you don’t need A/C or the microwave, a solar system would be sufficient. No noise, no gasoline, no lugging it in and out, no oil changes. Sizing a generator takes determining your electrical needs. Start with the A/C’s starting watts. What is it?
