Jan-22-2018 06:58 AM
Jan-25-2018 12:05 PM
Bud
USAF Retired
Pace Arrow
Jan-25-2018 11:24 AM
gmw photos wrote:LVJJJ wrote:
I've always tied into the Microwave circuit for extra kitchen appliances like toaster and coffee maker. Since the MW dual outlet usually has the 2nd plug-in holes sealed over, I just drill out the plastic where the plug holes should be then plug in a power strip and run the cord down to under the upper cabinets so then I have several outlets to use. If too many appliances are plugged in so they trip the breaker, then just unplug one or two.
Long ago when I wired the houses I built, seems to me you could put 8 or 10 outlets on a 15 amp circuit with 14-2 wire. So I have added up to 3 new outlets on a cicuit that has just one, usually able to run wires under the dinette seats or inside cabinets.
Exactly the way it was in my trailer, except it really was a single plug outlet they had the M/Wave plugged into. I replaced it with a duplex outlet that I plugged a powerstrip into. Giving me, mostly hidden up under there, a place to plug the coffee pot in.
Jan-25-2018 05:01 AM
Jan-25-2018 04:18 AM
Jan-24-2018 05:51 PM
Jan-24-2018 01:47 PM
Jan-24-2018 11:20 AM
Jan-24-2018 09:06 AM
Jan-24-2018 06:37 AM
Jan-24-2018 06:25 AM
enblethen wrote:
hilandfrog:
Tha is not correct information as the OP has a 50 amp rig. He will have a main and some branch breakers. Normally three full size connections to each side of leg. he could then replace full size breakers on the branch circuits with twin breakers.
Jan-24-2018 05:38 AM
Jan-23-2018 01:50 PM
Jan-23-2018 12:49 PM
westend wrote:gmw photos wrote:A twin breaker in one slot is two branch circuits. A branch is described as an independent wire run to devices. I see you have 8 branch circuits.enblethen wrote:
hilandfrog:
Allow me to show my ignorance of this subject. If a breaker is a "twin", does that define it as two branch circuits or one ?
Here is my 30A box. You can see the breaker I added at the bottom.
Each breaker above that is factory installed. How many branch circuits is this ?
As someone else remarked, adding a breaker would be best distribution if put on the opposite leg from the water heater. If a guy really wanted to achieve code compliance, add in a twin breaker and wire the new duplex receptacle with two branch circuits. This assumes the receptacle will be located in a kitchen area. I would use a twin 20 amp breaker and AWG 12 for this purpose.
Barney's installation of an exterior auxiliary power inlet is a good fix for those with 30 amp service. For those with 50 amp service, it probably won't be necessary.
Jan-23-2018 12:13 PM
Bud
USAF Retired
Pace Arrow
Jan-23-2018 12:12 PM
hilandfrog:
