LineC
Jul 28, 2015Explorer
New (to me) Truck Camper ?'s
So decided to take the plunge and get into the truck camper world. Been doing a lot of searching and his forum is truly an asset for a newbie. Couple questions though for you experienced guys.
My truck is a:
2005 2500hd SRW SB 4x4 Ext-cab w/8.1 & Allison. 1 ton AAM rear axle
Put Bilstein 5100 & Stableloads on it
Load E 245/75R16 Yokohoma AT/S (max load 3042lb)
Camper is a 08 Lance 830 w/2200lb dry weight
Question is inside the glove box it says "cargo weight rating" 2120lb
Anyone have a similar setup and what should I expect. Going to get it weighed once I get it loaded up just looking to see if I can piggyback on anyone else's experiences or other items that would be needed before I head out.
On the Lance I noticed they use the 8gauge power wire for the fridge and not the standard 7 way plug. . Thinking I can T off my back harness and utilize all the wires except for the power wire and run a 8ga to the battery. Trying to do this with minimal splicing. Anyone have a better setup or link to a prefabbed wire harness. My truck doesn't have the camper option with the extra harness next to the fuel tank.
Also trying to get a list of necessities ready. What would be some of the must haves you guys have learned throughout the years?
My truck is a:
