new to the TT world
oil8390
We just purchased a 2019 Catalina 172BHS and are super excited to use it. I have a couple of questions.
Do you recommend driving with the water tank full? if not, how easy is it to fill up at campgrounds?
Also any tips on locking the propane bottle and battery box to the frame of the trailer while its in storage?
Thanks.
Justin
32 REPLIES 32
gpeade
To the OP...as you can see here there are about as many opinions here as there are different rigs. My suggestion is try both and do whichever is best for you and your camping style. There is no right or wrong way. Once you camp a few times you will develop your own system and it will become routine to you personally. Don't sweat the small stuff just get out there and enjoy it! Personally I have never put a drop of water in the freshwater tank.
drsteve
Guys with half ton trucks and 18'TTs get essentially the same mileage as rigs twice as large. Because once you get them up to speed, only one thing really matters: Wind resistance. Aerodynamics is much more significant than a few hundred pounds of water.
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
Boomerweps
Notice nobody here is really making a big argument for mpg difference being a major consideration. As most have mentioned, they didn't notice the difference. All so called mpg experts, everywhere, says weight makes a difference. They just won't say how much ( or how little ;).
RVs with smaller CCC, then the extra water can make a noticeable difference. WHEN I start traveling anticipating dry camping, I will haul 1/4-1/3 tank for bathroom use. I will have to cut back more on the stuff we have previously packed in the TT.
I have previously used the cheaper in line water filters for CG use and now have a better quality one.
I, too, haul filtered water in jugs for drinking & cooking. I have found out how much I need per day average and cut back on those jugs, again to save CCC weight. When traveling for extended time, I will use my Berkey style drip filter for clean, fresh water.
My wife treated stocking the TT like a cabin on the lake. After my CAT scale weighing, we cut back significantly and keep aware of not taking a lot of extra nice to have, just in case, but seldom or never used stuff. Last camping trip was our most easy going, laid back, and we packed about half as much as before. Last year was our first year with a TT.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, ITBC, SumoSprings,
Ride_S40T
profdant139 wrote:
True, the MPG will not vary much, empty or full. But the more "deadweight" you carry, the more the wear and tear on your running gear -- the trailer's and the tow vehicle's suspensions and tires. So that is something to consider. Not a huge make or break issue, but not irrelevant, either.
I often wondered what that extra weight would do to MPG. When we purchased new, they left the freshwater tank about 2/3 full. We pulled home and was even able to run on cruise control for several mile stretch on the flats with our 1/2 ton.
Since then, we've been pulling with empty tanks and have yet to experience a time when the truck felt like it could effectively pull while on cruise. Last trip we filled about half full and it seemed to pull easier and track better. Not sure if the water is putting weight on the trailer springs to allow it to track easier or what. Lowering center of gravity? Dunno. Our trailer has approx 2200lb cargo capacity so maybe the beefy springs are smoothing out with the weight.
Never noticed a difference in MPG with water on board (grey/fresh/black). Lucky, I guess.
2021 Grand Design 268BH
2019 GMC Sierra Denali HD 3500 SRW
Traveling K9s Diesel and Roger
profdant139
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
ZINGERLITE
i was waiting until we got to the camp ground to fill my first few trips. we got set up one friday night, camper leveled, plugged in, unhitched and as i was putting the awning out the wife says "did you fill the water tank?" had to break down and go fill up.
Now i realize that the extra small fraction of an MPG isn't worth feeling like a dumb*ss lol. filling the water tank is now part of my procedure the night before we leave.
CavemanCharlie
I always travel with my fresh water tank full. I am just a weekend camper. I fill it up the day before, when I get to the campground I am ready to go and do stuff, I don't want to waste the time to fill the tank.
The water at the campground might not be that good.
And, some of the campgrounds I go to are a First Come, First Serve basis so I want to grab a spot right away.
dave54
Full or nearly full here. I have not noticed much of MPG difference.
Depending upon your configuration, a full tank may make the TT more stable in winds. A lot of weight low and directly above the axles. My rig has very little difference in hitch weight full or empty, but pulls a whole lot more stable. Also, you never know when you must make an unplanned overnight in someplace dry.
Just because a CG water supply meets health and safety standards does not mean it tastes good. Plenty of times I found the water undrinkable because of minerals and smell.
So many campsites, so little time...
ependydad
K_and_I wrote:
ependydad wrote:
Y'all
You've been in the South too long. Time to head back North.:B
๐Ÿ˜„
Someone once told me that Florida technically isnโ€™t โ€œthe Southโ€ because most everyone are transplants.
I tried explaining that to a Floridian the other day- she was offended. I probably should have done it *after* we got our food!
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
Ralph_Cramden
X
Too many geezers, self appointed moderators, experts, and disappearing posts for me. Enjoy. How many times can the same thing be rehashed over and over?
toedtoes
I always fill before a trip. It does NOT affect my MPG at all (get the same mileage when I drive home with the empty tanks).
As I stay at public campgrounds (USFS, COE, BOR, etc.), filling up at the campground is not an option. And even if I could use a water bandit and do it anyway, they often have limited water at those campgrounds. If I can bring enough water for my needs, then that means a tent camper can use the campground water for their needs.
And I use my tank even at places with hookups. I LIKE my tap water at home. I don't drink bottled water (some brands actually bottle the same water that comes out of my tap). I drink it, clean with it, cook with it.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
K_and_I
naturist wrote:
K_and_I wrote:
ependydad wrote:
Y'all
Thatโ€™s โ€œup nawthโ€ to you.
I'm not quite that far north ๐Ÿ™‚
K_and_I
2011 Rockwood 2604
Nights Camped in 2019: 85
Do we have time for shortcuts?
camper1013
If I know the campground has water at the site I don't take water with. If there is not water at the site, or we are off the grid I fill up at home. I do notice a difference in pulling empty vs full, but my water tank in in the front, so more hitch weight.
We have never drank the water in the tank, or campgrounds. We take bottled water.
I do like to have a few gallons while traveling for bathroom breaks. Also had to give a kid a shower once after a blowout on the road.
campinia
I always travel with full tanks and have similar CCC as you - 1200lbs. It is much easier to fill at home with water and have the use of it on the way and know that it is from a good source. I would not worry about a change in MPG, you will probably get 8-10 mpg towing as most do.
2017 Chevy Silverado Crew Cab LT 2500HD Z71 4X4 6.0 Gasser
2018 Keystone Passport Ultra Light 175BH
Champion 3100W Inverter Generator
2018 Pescador Pro 10 Fishing Kayak
2018 Old Town Topwater 106 Fishing Kayak
