New trailer wheel bearings
ifd22
Just purchased a 2016 shadow cruiser 280qbs. We plan on taking several small trips (under a hundred miles) this spring. We are then taking a 1900 mile round trip to Disney world this summer.
I normally repack my wheel bearings every two years, however this is my first new trailer.
Question is, how well does the factory normally grease the bearings on new travel trailers? Should I be good this first year, or with a long trip planned this year would I be better off re-packing them myself before we take the long trip?
2019 Primetime lite Crusader
2018 Ram 2500 Crewcab CTD
Andersen hitch
25 REPLIES 25
westend
I'm going to guess here but a large majority of trailer axles are being furnished by Lippert or Dexter. Both would have about the same assembly techniques and there isn't much wasted with grease or accurate bearing torque values.
If I bought a new trailer off a dealer lot or even at the factory, the hubs would be pulled, bearings and brakes serviced, and the whole reassembled with attention to detail. It would be worth it to me to know that the bearings were lubricated and set correctly, the brake parts all aligned and any lubing done to facilitate good brake operation. It's something that only takes a couple hours and can then be peace of mind for many miles.
'03 F-250 4x4 CC
tragusa3
Our last trailer was new. We had a bearing failure in the middle of nowhere in Arizona. At that point, the trailer had about 3k miles on it. It cost nearly $400 to have it repaired roadside (single axle, I was stranded). We got the other side repacked when we got to the next town. I watched the mechanic pull it apart...it was BONE dry.
My current trailer has about 2k miles on it now, and I keep putting it off...I guess I have to learn the really, really hard way. 🙂 We leave for a 6k mile trip in June. Best believe they will all be repacked before then.
New to us 2011 Tiffin Allegro Open Road 34TGA
Join us on the road at Rolling Ragu on YouTube!
Lynnmor
Chuck_thehammer wrote:
nothing about wheel bearings... just asking employees if piece work was normal at this place of business..
showed many doing assembly.. floors, walls, cabinets... etc. slap and staple..
The complete axle assemblies are delivered to the RV builder ready to install. The spring bolts are all that the builder installs. It doesn't much matter the brand or price, you all get the same grease, quality of components and assembly skills.
Now, from what I have been told, the axle companies are rather crude operations as well.
Chuck_thehammer
remove/inspect/service/reassemble. check brakes while there...
the assemblers are paid by the piece. Speed is everything...
always inspect before a LONG TRIP. your insurance . even NEW.. or because of NEW.
why do you think Cars/light trucks no longer use taper roller bearing in front wheels. assembly time.
What makes you think they're paid by the piece vs paid by the hour? Just curious. Do you have inside info?
I guess you missed the PBS show on the RV industry... and the Amish employees.. a few years ago..
Yes, I did miss it.
Did it say wheel bearings are assembled by Amish who are paid by the piece?
ifd22
Campfire Time wrote:
ifd22 wrote:
and yes I know the EZ lube axles are worthless. Thanks.
Nope, not worthless. Just misunderstood and misused. Follow Dexter's instructions and they are fine. They don't replace a good inspection every couple of years (and neither does Dexter suggest skipping inspections) but they do work as advertised.
Worthless, may of been the wrong wording. I'm sure they can work as advertised. I just don't trust them or should I say the grease seal. Actually having my hands and eyes involved with packing the grease on the bearings, and knowing I haven't forced any grease past the seal onto my brakes just makes me feel better. Probably why 99% of the time I do all of my home and auto repairs myself.
Andersen hitch
captnjack
Yes, I did miss it.
Chuck_thehammer
wrenchbender
To be safer than sorry,pull a wheel and inspect.A good repack will last 20k or better
Boon_Docker
ifd22 wrote:
.......and yes I know the EZ lube axles are worthless. Thanks.
I have been using my worthless EZ-Lube for years with no problems. If you use them correctly then you won't ever have a problem.
Campfire_Time
Chuck D.
“Adventure is just bad planning.” - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
jmckelvy
You have received good feedback re the grease.
Another thing to make absolutely sure of is that both sides (ESPECIALLY the driver side) have the cotter pins installed to keep the castle nut from rotating. I narrowly avoided a disaster on a previous Fifth wheel because the factory did not install a pin on the driver side. Castle nut came completely off, wheel was smoking before I was flagged down.
06 RAM 3500,Dually,CTD,Auto(ATS Stage 1),QC,4X4,PacBrake,Spyntec Freespin Hubs,60 Gal Titan Tank,EFI Live, Line-X,Torklifts and SuperHitch,Fastguns
2013 Arctic Fox 990, 275 Watts Solar, 2 Grp 31 AGMs
US Navy 1964-1968, 2-Tour Vietnam Vet
coolbreeze01
ifd22 wrote:
Thanks for the reply's. You pretty much confirmed my feelings. I'll be sure to repack the bearings this spring, and yes I know the EZ lube axles are worthless. Thanks.
Good call on the hand pack. Had mine done and all 4 seem to run cooler by touch.
2014 Sandsport 26FBSL
captnjack
hvac
You guys make me feel guilty. Ordered a custom built Livin Lite 21 RBS in March of 2104, delivered in May, with Dexter torsion suspension, all 4 are independent. So far it has about 18k miles, never checked the bearings. Thinking was every 2 years was ok and justified it was under full warranty, maybe this is a higher end axle and grease is a good investment for them??
