Apr-21-2016 02:58 PM
May-04-2016 12:06 PM
May-02-2016 05:34 AM
May-02-2016 04:56 AM
Mike Up wrote:RinconVTR wrote:Retired JSO wrote:
I have a sway pro and now 2000 lb bars on a work and play wb25 pulled by a 2016 f250. I kept experiencing sway even after changing from 1500 to 2000 lb bars. I quizzed e trailer and other ford forums and discovered the ford trucks with built in sway control act against the actions of the sway pro making the trailer sway more. We just returned from Charleston, about 260 miles. I had turned the sway control off, you have to do it every time you start the truck, and drove all the way with one hand and no, no sway.
Yup. This is also what I recommended the OP try. This is a common situation, but few Ford owners want to come out and talk about it, or they dont realize TSC can be part of the problem.
My post was without the explanation as I dont own a Ford. But I have hands on, direct knowledge and experience with this.
This is why turning off TSC is worth trying when people are experiencing problems, to feel the difference with it on and off, and confirm if it has a negative affect on your set up...or not.
No one wants to hear this...no one wants to believe it...but its real.
Hum, I've towed my current trailer with a 2010 and 2012 F150 with Electronic Sway control turned on, plus with a Reese Strait-Line System (HP Dual Cam Sway Control), never any sway.
May-01-2016 07:18 PM
Mwolfe450 wrote:
Wow. Thanks for all of the input. I haven't had time to mess with the setup, I am hoping to do so soon. I understand I am at or above the limits of the truck once the trailer is loaded. I towed it home empty, with nothing in it. So I towed an 8k trailer with a 950lb tongue weight trailer and it was bad. I understand weight capacities are glorified on trucks, especially 1/2 tons. I have towed 10k with the truck and had no complaints, but that was an open trailer, much different than a 32ft sail. I also feel some people have responded thinking the truck had no suspension left with the trailer. In fact, I felt it had way to much travel left for being at capacity. When I took some resistance out of the bars it certainly helped. Not sure of tires on the truck but they're oem goodyears definitely not e rated, I'll guess lt tires. Payload on the truck is 2060lbs. Yes that's including passengers which is less than 550lbs. So I have 1500lb carrying capacity being conservative in the truck. The trailer would generally be towed fairly light for small weekend trips and full hookup sites. The dealers setup had the trailer level to slightly nose up. I will set the hitch up according to instructions and nose the trailer slightly and re try it. Then I will add tongue weight and try again. Lastly I will hitch it up to a v10 250 and see how that is. will the 250 pull it better, absolutely. If I'm still not comfortable in the f150 I will get a different trailer. I guess my original question in my first post was what might make it so squirrelly empty? Would prowler sell such an unbalanced trailer? Or can a poorly set up hitch cause that much sway?
May-01-2016 06:48 PM
May-01-2016 06:33 PM
May-01-2016 03:51 PM
Apr-30-2016 06:16 PM
Apr-26-2016 08:34 AM
Apr-26-2016 07:41 AM
Apr-26-2016 06:28 AM
LarryJM wrote:ROBERTSUNRUS wrote:RinconVTR wrote:ROBERTSUNRUS wrote:camp-n-family wrote:
The Hensley and Pro-prides are excellent hitches, but they are not fixes for under sized trucks.
🙂 Hi, and the weight of these hitches will take up more of your payload.
Not exactly.
On a scale with a trailer...what does the payload rating mean to you?
Correct answer = NOTHING.
When towing, you are "combined" and weights on the scale are what matter. Axle weights and gross combined what you need to focus on. Not payload. A TT with WDH this becomes more useful info than a 5th wheel, however the same basic statement remains true.
🙂 Hi, and your answer is just a play on words. Mentioning payload is simpler for some people to understand. Yes, the extra 150 lbs of a Hensley type hitch can put some people over their payload, GVWR, GAWR, or GVWR. You/I don't want to go over any of your vehicle ratings. Payload is just one of them and one not to be ignored.
I agree and IMO it was RinconVTR's "broad statement" about payload that was bad advice and quite a few posters have correctly pointed out and I agree with. Payload is a very important number for planning purposes to try and ensure you don't bust any of the more specific numbers such as AWRs when you finally get to a set of scales.
Larry
Apr-26-2016 05:52 AM
RinconVTR wrote:
.....snip.....
If you are going to post a bold comment like this I would suggest you state why PRECISELY why the advice the advice is bad.
I bet you'll figure out before posting again.
Apr-26-2016 05:42 AM
Apr-26-2016 01:45 AM
