handye9
Apr 13, 2017Explorer II
wizards8507 wrote:
One of the things I got the dealer to include with the purchase is the installation of the OEM towing equipment, including hitch receiver, wiring, and labor.
My understanding was that the towing capacity of this vehicle is 3,600 lbs. I know there's some math involved to get to "true" towing capabilities, but this should be more than enough to tow a small pop-up tent trailer we plan on purchasing.
The additional equipment, being installed by the dealer, is only part of the OEM towing package. The full package would include an auxiliary transmission cooler.
The math used to determine "true towing capacity", is to calculate the weight of all the people, pets, and cargo, you will be taking on your camping trip. Add another 100 lbs for a weight distributing hitch, if you need to use one. Look at the tire and loading sticker, on your drivers door post. It will show a max occupant / cargo weight.
Now, subtract your family / planned cargo weight from both, the max occupant / cargo weight number, and from the max tow rating. What you have left (on the occupant / cargo number) is the payload you have available to carry the trailer's tongue weight. What you have left on the max tow rating, is your true tow capacity.
Example:
Say your numbers are:
Max occupant / cargo weight rating 1100 lbs
Max tow rating 3600 lbs
Family and planned cargo weight of 700 lbs
Your "true tow capacity" would be 2900 lbs (3600 minus 700) and your capacity to carry hitch and tongue weight would be 400 lbs (1100 minus 700).
Note 1: There is a post above, recommending a brake controller, that would only be required if the pup had electric brakes. Many do not have them.
Note 2: Primary purpose of a weight distributing hitch is to restore lost weight on your front axle. When you hang the trailer tongue weight on the hitch, it makes your vehicle sag like a see saw, adding weight on the rear axle and removing weight from your front axle. Too much weight off the front axle can cause steering problems. The distributing hitch uses leveraging to push some (in some cases all) of that lost weight back to the front axle. You probably won't need this either.
