Lumber81's avatar
Lumber81
Newbie needs help.
I have a stock 2001 Ford F350 Diesel 4x4 LWB SRW Crew Cab truck with E-Rated tires at 3415lbs and Ranch Hand bumpers front and rear. Last but not least 12,000lb winch. What is the heaviest dry weight camper I should look at without modifying my truck. The used camper that I am looking at has just over a 4,000lb mfg weight. Is that going to be to heavy. Just going to be using regionally for now, no cross country trips.
New info:
GVWR 9,900 , Front axle 5,200 , Rear axle 6,830
Actual weight: 7,740 Gross , 4,780 Front axle , 2,960 Rear axle
