uglybear11
Jul 06, 2014Explorer
newbie questions
i am new to travel trailers. I purchased a sunvally extreme 160 trailer. it is in pretty good shape but i have a few questions - please.
1. the water tank has a pump. It is operated by a switch. Do i leave the switch turned on or just turn it on while i know that we will be using the water?
2. the bathtub faucet has the hot and cold water controls. from the bottom side is a hose going to the hand held shower. there is a diverted valve between the knobs. The top of the divert er is broken off. a square stub extends approx 1/2 inch above the fixture. Can i glue a socket or other device to it to get by until, i have time and money to replace the faucet assembly? what kind of glue would be recommended?
3. can i frame a glass mirror and mount this to a wall via screws? or will the vibration / bounce of trailer shatter the mirror? i have already made and mounted - did i mess up? the mirror is approx 12*12 inches
4. the heater ..... how do i find the brand, model number, etc? i do not see this on the in or outside? i have found all of the remainder of the literature for each appliance.
5. i have a domestic refrigerator. the freezer door is messed up. it pivots downward. the pivots are broken. any suggestions? can i just run without the freezer door until it is fixed? or just hold it in place when the fridge door gets open?
6. tires. it has the original 2006 tires on it. the spare has never been on the ground. the previous owner said that he towed it very little - just left it at his deer lease. i have heard that tires of an age of over 5 years should be replaced?
sorry for so many questions ...... just get started and have a few so i hope that no one minds? help would be appreciated.
thanks
carter
thanks
carter
