SoundGuy
Jan 13, 2018Explorer
Huntindog wrote:
FYI
For those that are advocating being able to use the TT with the slides in.....
You are NOT supposed to use the slides when they are retracted.
the slides are mostly unsupported and at their weakest then. Most all manufacturers warn against doing this.
I am unaware of ANY that say it's OK.
FYI
Declaring this doesn't make it so. :R
I just went through all 48 pages of my "Coachmen Travel Trailer / Fifth Wheel Owner's Manual" and nowhere does it make any mention of any kind saying the slide(s) can't be used when retracted. My own 2014 Coachmen Freedom Express has now been through 5 camping seasons and I use it with the slide retracted much more often than I do with it deployed, especially here at the house where I'm in it pretty well every day. I've had no issues with this slide to date and because this is our first slide trailer I question whether the day will come when it won't behave as it should but I have no reason to believe it would have anything to do with using the slide in the retracted position. If anything, any failure would be the result of misalignment or excessive wear caused by repeated use. Coachmen doesn't caution against using the slide in the retracted position and without documented proof to the contrary nor should you without a link to documentation that indicates otherwise.
