kaydeejay wrote:
Speedogomer wrote:
Nitrogen is put into tires because it's not as sensitive to temperature changes. It won't drop pressure when it's cold or raise pressure when it's hot out.
Plain WRONG! Nitrogen follows the same temperature and pressure rules ("Boyle's Law) as any other gas.
The only reasonably legitimate reason for using Nitrogen is that it is probably drier than regular air.
Maybe I should have been more specific. Nitrogen drops and raises pressure less than compressed air due to the lack of moisture in nitrogen as opposed to air.
