Hi Sir Buffalo, Are you saying a fuse fixed the issue? Or were you saying thanks for the suggestion and you'll investigate the fuse? If it's not fixed can you give us more symptoms? Are you turning the switch or? Is the fan coming on but no heat? Does the fan run for a minute or so then turn off? Do you hear any noise at all?
Hopefully you already have it fixed.
