Apr-23-2014 09:24 AM
Apr-29-2014 02:46 AM
Apr-25-2014 06:34 PM
wmoses wrote:
Kenny - please ensure that once you get it sorted you let us know what the solution was to this mystery.
Apr-23-2014 10:16 PM
Apr-23-2014 08:39 PM
kennyd63 wrote:kaydeejay wrote:I already did that, and nothing still no water...:M
Short term, if you can't solve the problem, fill your water tank and run off the pump.
Apr-23-2014 08:25 PM
Apr-23-2014 04:25 PM
Apr-23-2014 03:54 PM
NanciL wrote:That would not prevent the system from working if there is water in the holding tank and the pump is on.
That white plastic nipple with the spring is a check valve to prevent water flowing back from your system into the city water supply.
If your water heater bypass system is working properly, and water is coming out of the hose, then the check valve is probably defective and preventing water from flowing in.
Jack L
Apr-23-2014 03:53 PM
kennyd63 wrote:Hmmm, you have at least one (probably two) in-line valves in your system that were closed when the TT was winterized.kaydeejay wrote:I already did that, and nothing still no water...:M
Apr-23-2014 02:37 PM
Apr-23-2014 01:05 PM
Apr-23-2014 10:08 AM
Apr-23-2014 09:48 AM
Jim Cindy wrote:
Check for winterizing valve in the line, turn 90 degrees.
Apr-23-2014 09:37 AM
