Mike63376's avatar
Mike63376
Norcold refrigerator flash code
Our norcold refrigerator power light is flashing once every 10 seconds. Fault recombination are thermistor bad or low battery shut-off switch needs to be in position 1 or 3. Where is the thermistor and where would the low battery shot-off switch be located?
  • Post the MODEL of your Norcold
    LED ON flashing once every 10 seconds????
    Haven't seen that fault code before
    Thermistor....
    Temp probe on food comparment FIN
    Thermostat uses the fedback from thermistor to control cooling cycles
    Bad thermistor-unplugged thermistor causes BOS (Backup Operating System) to control fridge temp based on TIME vs TEMP
    Model of Norcold???
  • The Thermistor is inside the refrigerator clipped to the fins at the back. I don't know about a low battery switch.
