sidney's avatar
sidney
OBD2 WI-FI Scanner
Has anyone tried one of these code scanners with an iPad or iPhone?
Link
  • I have not seen any application for iOS that is anything close to Torque Pro for Android. You can pick up a pre-paid wireless andtroid-based phone for $50, never make any calls and use as a Torque Pro display only plus $5 app and $15 bluetooth receiver.
  • If you get the torque PRO app (5 dollars) it works on the Ford diesels well. You can set up with ICP reading as well while driving down road. Neat and I use it on all our cars too. Blue tooth works great and I can run live data as you drive plus clear codes. Yes thiks works on Powerstroke Diesel
    Here it is for Android and it works great on my Galaxy S3.
    There are others for I Phone
    https://play.google.com/store/apps/details?id=org.prowl.torque&hl=en
  • Yes it works well. It will allow you to create many different gauges depending on your vehicle. I have an old droid that I use a monitor. You can also reset codes with it.
  • powderman426 wrote:
    No but I use one on android. Try an app called torque if its available for ios.
    Does it work well?
    Is it useful?
    Thanks
  • No but I use one on android. Try an app called torque if its available for ios.
