Observations - Going from an '01 F350 DRW to a '15 F450
Boatycall
Going from a 7.3L to a 6.7L. I was chatting with JimH and he said I should post my impression of old truck vs. new.
I just came back Saturday from 9 days in the north Idaho Rockies, loaded with all the toys, about 350 miles each way. Thought I would post my observations from my first roadtrip with my 'new to me' 2015 F450.
Wow. That's all I gotta say.... wow.
Everything is so much better...Power, suspension, power, ride comfort, power, and stability. I had done pretty much everything you could do to an '01 DRW to haul a TC and trailer, short of pulling the motor and having it professionally built---
*Banks Turbo
*Banks Cold Air Intake
*4" full turbo back exhaust
*Superchips tuner set to 'Race'/110hp for the last 10 or so years--with of course all the standard gauges to make sure I didn't over-do it.
*Roadmaster Sway Bars
*Rancho 9000's
*MosterBox $4k aftermarket Tranny
*F550 rear suspension w/Torklift StableLoads
The new F450 - bone stock except for StableLoads and Bags(needed both - bags alone, 100psi, StableLoads alone - camper alone was fine, but adding trailer tongue weight made it sag).
So, I was running ~26k/27kLbs. We have four hard pulls between me and North Idaho -- used to pull Tiger Mtn @45, now 60 with pedal to spare. Snoqualmie, speed limit all the way from North Bend to the top....just set the cruise control, hit "Tow/Haul" and let it do it's thing. Used to be 45-50 in my old truck max'ing out the pyro near the top. In the new truck, I actually had to slow down to take the final turn at the top. Vantage - 70. 4th of July Pass in Idaho - again, the corners were my limiting factor. Last year, 45mph tops.
My old truck - you were fully aware of the fact you were pushing it hard, turbo noise, exhaust, radiator fan coming on and off like a big jet engine. This thing, nothing. No noise other than Freebird coming out of the stereo. Coming down - Jake brake was absolutely awesome. Coming back down Snoqualmie, set the cruise at 65 and it just kept downshifting till it held it. Went from 6th to 4th, then on the level spots back to 6th.
And - I got better MPG to boot. The Lie-O-Meter is dead on compared to hand calculated. Pulling all those passes loaded I would average 7.5mpg there, 8 back. I was 8.5 there, 9.0 back. It went into Regen twice which killed it, I was a one point at 9.5 before that kicked in. I smell a full DPF delete in my future.
I bought a brand new Firestone airbag kit for it and put it on prior to leaving since the Stableloads didn't quite make it on the stock springs. Have to decide whether I'm going to keep them or ditch the bags for an overload spring pack and StableLoads like my old truck.
'15 F450, 30k Superhitch, 48" Supertruss, 19.5's, Torklift Fast Guns
'12 Eagle Cap 1160, 800watts solar, Tristar MPPT, Magnum Hybrid 3k Inverter
'15 Wells Cargo 24' Race Trailer, 600 watts Solar, TriStar MPPT, Xantrex 2kw inverter
'17 Can Am X3 XDS Turbo
14 REPLIES 14
HMS_Beagle
My 6.7L is better in every way than the 7.3L - except complexity. Quieter, no stink, MUCH more power, better brakes, MUCH better engine braking, better transmission by far. The two trucks ('99 and '15) are as close to the same spec otherwise as can be done from the order book.
A lot of complexity though, if it breaks.
Bigfoot 10.4E, 2015 F350 6.7L DRW 2WD, Autoflex Ultra Air Ride rear suspension, Hellwig Bigwig sway bars front and rear
mellow
That is what I figured, wasn't sure if a newer 19.5 has come out that would be better suited for beach driving on lower PSI, I was looking at 450's as well but I do a majority of my camping on the beach. Looking at a heavy TC with slides for more room for the kids but might just have to stick with a hardside to keep the weight down.
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
jimh406
In case it isn't obvious, DRWs aren't the best for sand with or without 19.5s. I've driven trucks with 19.5s on the beach without issue, and I've also driven a Class A on the beach and seen many other RVs.
I also know people who have got stuck with 4x4s with wide tires. It all depends on the beach and the driver whether it is doable or not.
Bedlam
Moderator
Moderator
The 19.5's will not flatten. You can drive on packed sand, but they dig in the soft bottomless stuff.
mellow
Will the 19.5's deflate enough to drive on the beach in 4wd?
CAJW
Since I'm a Chevy guy, my interest was peaked at Freebird. Saw them do that live in 75', my ears are still ringing! Glad the new rig has worked out so well.
2013 AF 996, 2013 Chevy 3500 CC,LWB,4X4, Duramax, DRW, 3.73 rear, Torklift Stableloads & Tie-downs,Fast Guns, Ride Rite Air Bags, Superhitch w/ 32" extension.Big Wigs, Front Timbrens, TST TPMS-507,CubbyCam, Trimetric. TM & SC 2030 150W + 100W suitcase
Buzzcut1
Nomad II
Nomad II
Congrats.
My 6.7 F350 DRW is going into the shop this weekend to fix a small oil leak at the oil pan gasket at 96k. I am loading the TC back on to my 6.0l F350 SRW with 19.5s, stable loads, and airbags to go work a horse show 80 miles away.
I know I will miss the power and stability.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Vinsil
pcoplin wrote:
I noticed quote a bit of difference in going from a 2001 7.3 truck, to a 2005 6.0 truck. The whole truck is more stable and has a better ride. The power is about the same, but the transmission is a LOT better. The engine braking in the rR110 is excellent.
Bulletproof and tune that beast...you won't say that anymore!!!
On my trip to CA this last week...I was pulling 65-68 mph on all the passes. Averaged 10.5 mpg over 1600 miles of hills and hauling azz.
2017 Ford F-350, crewcab, 4x4, 6.7 diesel.
2016 Thunderjet Luxor 21' limited edition, Yamaha powered.
2016 Wolf Creek 840-SOLD, Arctic Fox 990 ordered.
pcoplin
2005 F350 CCLB Dually 6.0/5R110
2009 Adventurer 950B
SoCalDesertRid1
That was great reading! Congrats on the new truck! ๐Ÿ™‚
Swapping to spring packs from an F450 cab/chassis should put you just right for rear suspension. Unfortunately, the F450 pickups don't get much more rear spring rate than the F350DRW pickups, despite the upgrade to that massive S-series rear axle.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
jimh406
F450s sure are fun. ๐Ÿ™‚
the_bear_II
Same feeling I had going from a Chevy 3500 DRW to my Chevy 4500 DRW. Wow it's like dream towing....Congrats on the new setup
nomadictxn
I bet you felt like a locomotive! That's a strong set up.
nomadictxn
2013 RAM 1500 QC 5.7, 3.92 4x4 6 sp.
2021 Flagstaff E Pro 19FBS
Vinsil
Thanks for the comparison. Those 6.7 scorpions are beasts, I too came from an old 7.3 that was not as worked over as yours (still factory charger) and moving on to my current truck....wow is all I can say.
You won't regret a delete and tune!!!!!!!!!
