Off Truck Camper Leveling
egarant
Hi,
We are all aware of keeping the front of the camper 4-6" higher than the rear when taking the camper off or putting it back on the truck.
My question is if it is OK to level the unit for camping use when it is on the ground. Even though I do like my head a bit above my feet, I would think you would have to level it in order for the fridge and other appliances to work properly.
2021 FORD F350 dually 4x4 with 4.30 gears, 013 Eagle Cap 950, 480 Watts Solar, 3K Victron Multiplus II, Victron smart DC-DC charger, Victron 100/30 solar controller, 250 amps of lithium batteries by LifeBlue
33 REPLIES 33
K_Mac
Raften wrote:
I have never understood the why of keeping the front higher when loading/unloading.
X 2
Raften
'01 Dodge 3500 CTD, Lance 1121, Air Bags, Rancho 9000, All Wheels Under Power When Needed, A Few Engine Mods For Increased HP
Burning Grease, 800 ft/lbs. of torque from something you throw away.
Butch50
I would say about an inch of two higher in the front than the back when off the truck. That amount is not going to make a hill of beans to the fridge. I would not make it level as it is no different than when loadking it on the truck. It is recommended to keep the front a couple of inches higher than the back it doesn't need to 4 to 6" higher and that can put quite a load on the rear jacks also.
Butch
I try to always leave doubt to my ignorance rather than prove it
2021 Winnebago View
AKSuperDually
You want the camper level whenever at rest, especially when running the fridge.
2000 Ford F350 DRW 4x4 7.3L
2003 Arctic Fox 1150
