jungleexplorer's avatar
Aug 07, 2014
Okay. What do I do now?
Well, after a lot of debate and advice I decided to stay with my current TV and see how it would do.
My TV: 2007 Silverado 1500, Quad Cab Short bed.
Engine: 5.3 V8
Trans: 4 speed auto with overdrive
Diff Ratio: 3.23
Tow Package: Stock with auxiliary trans cooler.
My TT: 2005 Kodiak 19FL
Length: 23ft
UVW: 3780 pounds
LVW: 5000 pounds (estimated loaded vehicle weight).
Okay. Today I took my rig for a test run. I have a bluetooth OBD2 scanner and the Torque app to monitor my transmission temp with. It was 100 degrees here and the trailer is weighing around 4000 pounds (still dry with only some clothes and stuff in it). I made it only 7 mile on flat ground before my trans mission temp hit 200 degrees. I drove 300 miles yesterday in my truck, unloaded without the trailer, and my transmission temp never got over 167 degrees and it was just as hot yesterday as it is today.
I was think about adding a an additional trans cooler but I don't know if it would just be better to get a lager TV. Advice?
