dodge guy wrote:
subcamper wrote:
dodge guy wrote:
Dog Folks wrote:
prichardson wrote:
That's a mid to late 60's Cadillac. Probably has a 429 ci engine and tips the scales around 4700# on a 224" wheel base. They were built on a frame that was probably as hefty as todays pickups. Only got at best 10 mpg even without a trailer.
Early 70's was when the auto makers went to "uni body" construction.
That means NO ladder frames, and thus towing became a pick up's job.
Towing, even light towing, with a uni body would twist the whole car and often crack the windshield.
Don't ask how I know.
Actually full frame cars disappeared when Fords Panther platform (Crown Vic, Grand Marquis, Town Car) went away! Back in 2011!
And as the OP stated that is a mid 70's Buick. Possibly an Olds? Probably a 455!
The full frame is only part of it.
The 2010 Ford Crown Victoria is only rated to tow 1500lbs!
So there is a lot more involved.
For example, it had been a long time since a really strong rear axle was put in a car (like the old Ford 9 inch and GM 12-bolt). I am not counting the special rear axles in V8 Corvettes and Camaros, they are built for high HP and peak torque but can't take the strain of a trailer pull up and down grades repeatedly.
The big rear axles and strong rear-drive transmissions are all in the trucks now.
I am sure the automakers aren't unhappy about all of us buying high-profit-margin trucks and SUVs either;).
Steve
Yes, but the tow rating was around 5500lbs? Back in the late 80's or early 90's. The only thing that changed was the tow rating. The Panther cars always had the 8.8 axle in them.
I agree that auto manuf. like is buying the more profitable trucks/Suv's......which is a good indication of the reason behind lowering the tow rating. this way they could get people into more profitable trucks!
Hi Dodge Guy....
My 94 Lincoln Town Car had a 4500 or 5500 lb tow rating.
It is nearly identical under the sheet metal to my 2000 Town Car that has a 2,000 lb tow rating.
What is different?
At one time I had mapped out the change and seems the only perceptible change was a move from a Full Size spare tire to a compact spare tire....2500-3500 lbs of tow rating lost due to a compact spare....
I would pull 5,000-6,500 lbs with my Town Car without thinking about it after I added a HD tranny cooler, brake controller, and a custom class IV Hitch.
The only issue with making the Town Car a serious tow car would be the rear axle ratio...I would swap the rear axle ratio to a 3.55 if I were serious. Possibly look at some higher load capacity tires too. I would also look at some HD Limo progressive coil springs for the rear axle...Oh yea, and a full size spare. Lol
Thanks!
Jeremiah
