Painting window frames??
vdubee
I'm looking to paint my "white" window frames on my North Trail black.I searched and couldn't find much info on doing this. Has anyone tackled this before or have any info to share??
3 REPLIES 3
Campfire_Time
Its just painted aluminum. Paint it like you would paint anything else for outdoor use. Lightly sand them with 400 or 600 grit paper. Clean them with a good surface cleaner. Spray with any good quality paint in a can made for metal and the outdoors. Tape it all off. Prior to spraying, warm up a pan of water, not hot, but very warm. Stick the can it in for a few minutes. This improves flow and gives you a more even spray, spray cans normally are not the best way to paint. Optionally you can follow up with a clear coat sealer.
Chuck D.
โ€œAdventure is just bad planning.โ€ - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
vdubee
Lebout, thanks for the reply!! However, I'm not talking about the door frame. I'm referring to all of the other side wall window frames.
LeBout
Yup. The window frames in my two doors were yellow and the rest of the windows have a black trim so I decided to paint the door window frames black. Just masked them off with tape and paper and used a semi-gloss spray paint. Turned out pretty good.
2020 Heartland Wilderness 2500RL
2013 Ford F-150 3.5L Eccoboost Supercrew 4x4, Max tow package
2 Honda 2000 watt Generators
Eastern Oregon, USA
Our Trailer
Our Floorplan
Days camped so far in 2020: 0
