Doug33's avatar
Doug33
paper thin bunk plywood
Yesterday I winterized the TT. In the process I had to access the hot water heater and the bypass valve. The water heater is located under the lower bunk. My particular TT model has the double bunks, which are very comfortable and easily accessable for even adults. I've actually slept in the lower bunk a couple times.
In order to get to the water heater I have to remove the mattress and then unscrew the "plywood" sheets and lift it out of the way. I was shocked at how thin the wood is. I knew I was in trouble, because when I crawled towards the back of the bunk to unscrew the far end, my knee started to go right through the wood, making a huge crack in it.
I know manufacturers are trying to save every almighty single pound from a TT, but this is absurd. I can't believe this wood supported anyone without collapsing.
After finishing winterizing, I didn't bother putting the wood back in place or screwing it down. If there is a warm spell, I will remove the thin wood, and replace it with something else that is stronger. I was thinking using a pressboard, but I know they are pretty heavy.
Has anyone else replaced their bunk plywood, and if so, what did you use to replace it with. I'm not too worried about adding a few pounds, but I would still like to keep it as light (and cheap) as possible.
Are their synthetic (plastic composite) alternatives to plywood or pressboard?
