Payload rating on F-450.
4wheelingNUT__
Ok, looked at F-450 Platinum 4wd, with all the bells, and whistles, has the fifthwheel prep pkg. The stamped limit was 4770 lbs for cargo payload carrying capacity. My question is, is that enough for a 3700 pound hitch weight toyhauler. Did Ford factor in the fifthwheel hitch already in this figure? Anyone with F-450's pulling large heavy toyhaulers please chime in.
54 REPLIES 54
MFL
Nomad II
Nomad II
If you are looking at your payload sticker, that is figured on the actual wt when the truck left the factory, which includes the under bed
fw prep, subtracted from the trucks GVWR. That truck is more than enough, for the FW pin wt you mention. The rear axle/tires are designed to carry plenty more.
Jerry
Trackrig
4wheelingNUT!! wrote:
Sport45 wrote:
If you look at the F-350 you’ll find they have more payload. Might be enough to make the difference you need. The 450 does give you a tighter turning radius and real truck tires though.
Yes the F-350 would most likely, I just really like the F450. Nothing set in stone though.
The F450 will also give you larger brakes. Well worth it to me for the heavy load.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
agesilaus
The weight claim is usually made on a stripped down truck with few if any accessories. And it varies quite a bit in the real world depending on axle ratios, engines, transmissions and so on.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
4wheelingNUT__
I understand the hitch is not a factor in the rating, but if the truck has the fifthwheel prep pkg from the factory, the hardware that comes on the truck from the factory, is that hardware a factor in the weight rating.
4wheelingNUT__
Sport45
’19 F350 SRW CCLB PSD Fx4
'00 F250, CC SWB 4x2, V-10 3.73LS. (sold)
'83 F100 SWB 4x2, 302 AOD 3.55. (parked)
'05 GMC Envoy 4x2 4.2 3.73L.
'12 Edge 2.0 Ecoboost
'15 Cherokee Trailhawk
4wheelingNUT__
Wander what the weight of the fifthwheel hitch would deduct?
Not sure what you are asking but a hitch weighs about 150-200#
Yes, thats exactly what I was asking. I was thinking probably a couple hundred, depending on the hitch.
agesilaus
Superbumper
4wheelingNUT__
agesilaus
No the hitch is not included in that number nor is the weights of the passengers, misc cargo or anything else. You may need a MDT
Superbumper
