cpaulsen
Jul 26, 2013Explorer
JerJan10 wrote:
The PCM code on my 2001 F250 7.3TD is on the engine side of the PCM, there is a white sticker with a bar code on it, down below the Master Cylinder where the nut is to remove the PCM, you will need a flashlight and a mirror on a stick to read it and remember you will be reading in backwards!!
I assume that the gas engine trucks would also have a PCM in the same location.
Same for a gas engine. You must be looking at getting a tuner.
44,030 PostsLatest Activity: Jan 21, 2025
