- cpaulsenExplorer
JerJan10 wrote:
The PCM code on my 2001 F250 7.3TD is on the engine side of the PCM, there is a white sticker with a bar code on it, down below the Master Cylinder where the nut is to remove the PCM, you will need a flashlight and a mirror on a stick to read it and remember you will be reading in backwards!!
I assume that the gas engine trucks would also have a PCM in the same location.
Same for a gas engine. You must be looking at getting a tuner. - JerJan10ExplorerThe PCM code on my 2001 F250 7.3TD is on the engine side of the PCM, there is a white sticker with a bar code on it, down below the Master Cylinder where the nut is to remove the PCM, you will need a flashlight and a mirror on a stick to read it and remember you will be reading in backwards!!
I assume that the gas engine trucks would also have a PCM in the same location. - wittmebaExplorerAssume you are referring to error codes.
These are generic for Ford. See if this helps: Advanced Auto and Other stores can diagnose and reset for free if you need.
http://www.obd-codes.com/trouble_codes/ford/
This may help too - home for above:
About Travel Trailer Group
44,030 PostsLatest Activity: Jan 21, 2025
