westend
Sep 20, 2015Explorer
I'd suggest to put some baking soda or peroxide into the system and flush it out thoroughly a couple more times. Make sure all pipes and valves are allowed to flush completely. I doubt you are tasting "plastic" as you describe it from the plumbing because the tank material is food grade polyethylene and PEX is inert to the water. It's more likely that you are tasting the residual antifreeze that was in the system or water from another source that had acquired a taste.
44,030 PostsLatest Activity: Oct 10, 2023
