Aug-13-2016 01:43 PM
Aug-14-2016 01:33 PM
APT wrote:
4000+ pounds of pin weight is dually range. I don't think early 2000's 1-ton duallys are rated for 17k+ pounds either, which is what your budget suggests. You may want to shift that budget a little.
Aug-14-2016 12:56 PM
Aug-14-2016 10:48 AM
Grit dog wrote:
If you had any experience towing you wouldn't be asking the question, so get the newest dually you can afford. And personally I wouldn't even think of towing that much long distances without it being a diesel.
$15k will get you a nice hopped up 2nd gen cummins Dodge. Look for a tuck with the 6 speed manual and enough go fast parts to make it pull like the newer trucks. That would be my choice on a budget. Or find the nicest early Duramax you can for the budget.
7.3 early super duty with 6 speed with some mods would be good too, but they're getting more scarce than the other 2 brands due to Fords 8 year hiatus from making good diesel pickups.
You'll have to shop hard for a deal and know what you're looking at to not get a clapped out older diesel as most all will be higher miles or still $20k for a dually 4x4.
2wd will save you a lot of money and potential repair costs as well.
Aug-14-2016 09:51 AM
Aug-14-2016 09:38 AM
wsalopek wrote:Chuck_thehammer wrote:
and remember. some trucks have hour meters... could be important. mine had 4,100 running hours for 138,000 miles
and 600 idle hours. so it was a Freeway truck. and did little towing... as hitch had little use/wear.
Chuck,
Interesting about the hour meter...what's a good ratio of hours to miles?
Bill
Aug-14-2016 08:21 AM
Aug-14-2016 08:18 AM
Aug-14-2016 08:09 AM
Aug-14-2016 05:10 AM
Aug-13-2016 10:13 PM
Aug-13-2016 04:53 PM
SoCalDesertRider wrote:
A 15,000 lb unloaded weight toy hauler could end up weighing 20,000 lbs loaded...Giving us the unloaded weight of the trailer really doesn't help at all. Nobody goes camping with an empty trailer, especially a toy hauler. What are you intending to haul in the trailer and how much does that weigh?
Aug-13-2016 04:46 PM
Aug-13-2016 04:45 PM
Aug-13-2016 03:28 PM
agesilaus wrote:
Dually's I've heard don't work well off road as a 4WD.
