Plugged in or Trickle Charger
oyarsa
Our trailer is now parked next to our house. I could keep it plugged in 24/7. Is it better to do that, or take the batteries out and plug them into Battery Tenders if the trailer isn't going to be used for a while (say a month.) Our batteries are regular, maintenance required deep cycle batteries. Our previous batteries died, I believe because they were left disconnected and not on any trickle charger for a few months. I'd like to try to treat these batteries better.
Also, the previous batteries had some corrosion on the positive terminals. This transferred to the Battery Tender connections. I assume I need to clean them before connecting to the new batteries, but how thoroughly do I need to clean them, how should I clean them, and should I use some sort of anti-corrosion spray?
43 REPLIES 43
oyarsa
jdc1, how do you mean, exactly?
The converter is a WFCO model WF-8955PEC.
Still trying to figure out the charger.
jdc1
Why not just wire you batteries for a trickle charger so you don't have to remove them? That's what I did to mine. But, I prefer just using my solar.....
oyarsa
Where would I find the converter and charger?
beemerphile1
There is no way anyone can give an accurate answer without knowing the brand and model of converter plus the brand and model of charger.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
pianotuna
Nomad III
Nomad III
I would leave the batteries in place. I'd add a trickle charger to them. Or add solar (which is what I chose).
Regards, Don
Huntindog
If you have a WFCO, it is a bad idea to just plug the trailer in.... WFCOs never go into float.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
KD4UPL
If your trailer has a modern day quality charger that treats your batteries well with proper charge voltage regulation then just leave everything plugged in. If you have an older trailer with a charger that tends to over or under charge batteries your probably better off not leaving it running for long periods of time.
What kind of charger/converter is built into your trailer? Have you measured the voltage it floats your batteries at?
Lwiddis
Small solar panel...30 watts...and a $22 controller from WindyNation with bulk, absorption, float and equalization capability...easy.
Ava
Use a slurry mix of baking soda and water to clean terminals. It will foam up and neutralize any acid. Then rinse off. Coat terminals with a commercial brand spray or just use Vaseline.
BarabooBob
My TT has a much better charger in it than most people have for a trickle charger. Some chargers put out a constant 13.4 volts which over time, can cause the batteries to dry up.
Bob & Dawn Married 34 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
Grit_dog
Navigator
Navigator
If they corrode with regularity, it's typically from overcharging pushing gas out around the terminals or just slight leak around the terminals.
If the latter and you want to get more time out of the batteries, clean up around the terminals and apply some rtv sealant. Works for a while
azdryheat
Mines been plugged in to the house (30 amp) it's whole life.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
Grit_dog
Navigator
Navigator
Yes you should do one or the other, at least periodically.
If your converter isn't a "smart" converter, i.e. Also a battery tender then it can/will overcharge the batteries.
Since you have a battery tender, hook it up and use it unless you can verify your converter does the same.
Only need one maintainer if you have 12V batteries.
Nothing fancy, wire brush or sand the corrosion off. It shouldn't corrode again quickly.
Also Coca Cola cleans battery terminal corrosion nicely.
kellem
Check water level twice a year and leave trailer plugged in.....charged battery won't freeze either.
If your trailer is close to level, keep frig running also as they'll last forever.
