Pop up purchasing question.
piney423
Hi all. New to the forum and have been looking at used pop ups for the past few months. Every one I have looked at has a moldy smell to it and that has caused me to walk away from them all. I've come to the conclusion that this might just be an unavoidable situation.
I looked at one this morning that clearly has some mold on the canvas. The owner said he has scrubbed it and it is stained. He also said it's a common occurrence. Is that true? Does the smell go away after the trailer has been opened for a bit? Any advice on purchasing would be greatly appreciated.
Thanks,
Mike
15 REPLIES 15
piney423
Thanks all. I picked up a 2003 Coleman Utah today from a dealer. Pick it up next Wednesday and am heading to Hickory Run State Park in the Poconos, PA to break it in Thursday.
Jester79
Good luck, piney423! In addition to the great information posted above, I think it also depends on how well the previous owner took care of the PUP. We were fortunate enough to buy ours a few years ago from a co-worker's parents. They were the original owners (bought it new in 1994) and took excellent care of it. They hadn't used it in YEARS when we bought it; but opening it up you would think that they religiously cleaned and cared for it. It does have the canvas smell from being outdoors, but that seems to be pretty unavoidable, and airing it out helps quite a bit.
Happy camping!!
Me
DH
DD (4)
DS (7 mos)
Chloe (9YO Scottie-Poo)
1994 Flagstaff by Cobra - Model 206
2009 Dodge Grand Caravan SE
lfloom
For a larger non canvas PUP, check out the trailmanor. We just made the switch. Fabulous (but pricey) unit. It is also much easier/faster to set up.
But, our two pups had little problem with mold. We live in So Cal, so it was easy to dry out after each trip.
piney423
Thanks all. Still looking. Might go new.
Alfred622
We got our pop-up when it was about 8 years old. It was in great condition, clean, and did NOT smell of mold. We kept it 4 years and used it a lot. It was always put away clean and dry. After 4 years it still looked great and had zero mold. I ended up selling it for $50 more than I paid for it. It was a Coleman with a one-piece top and cable lifts. I still miss that even though we now have a motorhome for our camping (just not the same as the pop-up).
Alfred
2005 Sightseer with Workhorse, ReadyBrute Elite towing 2003 Honda CRV
Map below shows states where we actually camped.....
Ex-Tech
One more thing regarding the lift systems:
The most common are the cable driven types with telescoping support posts such as Coleman and Starcraft. Some brands, such as my current Palomino, have external arms with spring assist either inside the arms where they fold or under the trailer itself like mine. While not as nice looking as the internal cable driven arms and needing a little more manpower to lift the roof, I prefer the external spring assist arms over the cable driven type because the external arms are more reliable and need no maintenance or adjustments. Cable systems can sometimes need adjustment and if a cable breaks, can be expensive and difficult to replace.
Monaco_Montclai
we had a nagara by Fleetwood. nice popup--now its all happy-cAMPING
Ex-Tech
Bought and sold more than 28 Pups over the past 30 years. Other than the hardside models ( and even this with canvas over the beds), they all have that tent trailer aroma. It is not mold. It is the canvas. Ever unpack a canvas tent after storing it? Same thing. Odor goes away after airing out.
As far as stains, not too easy to remove from canvas, Sunbrella or any other canvas alternative materials.
My current tent trailer is a 1986 Palomino with the folding hard-side walls. This model had vinyl over the beds and this has been the best I have had. Very easy to clean.
In these 30 years, I have had them all including Starcraft, Coleman, Palomino, Venture, Wheel Camper (antique), Viking, Jayco, you name it and my favorite has been the Palomino whether canvas or hard side. Why? Palominos have a roof system that uses a one piece aluminum sheet on the roof and the same aluminum inside on the ceiling. This is far better than most other brands that use a vinyl covered hardboard for the ceiling. Many I have purchased had this type of material peeling or stained because the trailer was folded up wet or because of sweating or water damage. Palominos don't have this issue with the aluminum ceiling. Just all MHO.
Just be sure to inspect the roof for water damage and dry rot. common issue with tent trailer roofs that were not properly maintained.
WHATEVER YOU DO, DO NOT PURCHASE A COLEMAN PRODUCT WITH THE ABS "PLASTIC" ROOF. These were well known for defective manufacturing with the roofs delaminating, cracking and sagging. Also, if you come across one that has a roof-air and the roof sags in the middle, most likely the roof has water damage.
Dakota98
Since you're in the market for a used pop-up the condition of the unit should be first & foremost. I have owned 6 over a period of 2 years, all purchased used. As far as quality & construction Coleman & Starcraft are the very best. You may want to start your search by narrowing it down to these two manufacturers & going from there. Having said that, condition of a used one is still most important.
Mold or mildew stains may be a common problem in high humidity climates, but most coaches should not have an obvious odor or smell to them as you indicated. A few stains in the covering materials won't cause an overwhelming odor when you walk into it. It takes a little effort, but my recommendation is to crawl under the coach & inspect it front to back, looking for any obvious water damaged & or soft spots in the flooring. Also, look at the siding of the trailer for bulges or abnormalities, this can indicate rotten wood behind the siding. Stains on the ceiling are always obvious but may not be a serious indicator of problems, the coach may of had a minor leak at one time that has since been repaired. Another thing to do is open the cabinet doors and inspect the flooring from inside the coach, but don't forget to inspect it from below. ( most important ). PS: the 6 units I purchased & used was over a period of 2 years doing minor repairs and reselling, making enough net profit to buy a 22' hard side & paying cash.
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
rexlion
Starcraft used a material called Aqualon, I think. Not canvas.
Look for signs of any water stains on the ceiling or walls, or softness in the floor (probe the underside with a screwdriver or similar object). If there is none, perhaps the smell is just from the trailer being stored all closed up. It might air out.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
piney423
Thanks so far. Those Aliners are nice but too small for my needs. I need to be able to sleep 4 adults comfortably at the minimum.
Does the smell dissipate after the camper has been open for a few hours? I know there are some products that remove mold and the smell so there is that option. I also worry that the mold is caused by leaks.
rrupert
If you can find a popup that uses Sunbrella instead of the old fashion canvas you will run a lesser chance of getting mold and mildew. Sunbrella is a breathable acrylic material. Coleman/Fleetwood used it with good success. Any camper will get mold and mildew if not maintained properly. They need to be put away dry, and if you can't put it away dry get it opened up ASAP to dry it out. DO NOT use water repellent on it.
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
Old_Days
If you do find a good used pop up spray KIWI Heavy Duty Water Repellent on the canvas it is a great product. Make sure to always have the canvas dry before storing.Good Luck in your search.
piney423
An interesting alternative. Thanks. Checking out their site now.
