Power issue
jamesfranci
I have a 2004 Fleetwood Pioneer and I am wondering if the power converter being bad would affect the hot water heater? No hot water even when plugged into power from the pole
7 REPLIES 7
Old-Biscuit
If it is a Suburban Brand.......no DC needed for 120V AC function (Unless it is a DEL model)
If it is a Atwood Brand ....being a 2004 it needs DC to trigger AC to element
Do the lights work, does the fridge display work, do you have other DC items that function OK........
DOes water heater heat on propane?
If YES.doubt it is a DC issue
Typically it is the element, wiring, t-stat of 120V AC Circuit breaker
But w/o BRAND/Model it is all guessing
jerryjay11
Accordingly to a spec sheet it is a DSI gas water heater so begin there to listen for a clicking sound when it attempts to light. No clicking then check power to the control module.
enblethen
Scott: he may have a pilot light model!
OP: How to you operate the water heater? Do you light it manually or do you turn a switch on?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
ScottG
If it isn't getting 12v it wont work. If it is, it will.
enblethen
Make and model of water heater?
Do you have winterizing valves? If so verify valves are in the correct possition.
DSI and 120 volt water heaters normally require 12 volts DC for control.
Bud
USAF Retired
Pace Arrow
FrankShore
Are you not getting any hot water? If yes, I doubt it would be the converter. The water heater would be the first culprit, the heating element, down to the t-stat the fuse.
2014 F-250
2014 Minnie Winnie 2351DKS (Traded In-Burnout-Use A Surge Protector!)
2015 Arctic Fox 22G (Great Trailer But Heavy - Traded In)
2018 Lance 1685 w/ Solar & 4 Seasons Package
1999 Beneteau 461 Oceanis Yacht
En Norski i en Fransk bรฅt - Dette mรฅ jeg se!
donn0128
Depends. Some water heaters need 12VDC. Standing pilot water heaters dont need anything but propane.
