QCMan
Mar 24, 2024Nomad III
Tongue weight is not the issue for a tongue jack. Keep in mind that you will be lifting the rear of the tow vehicle to instal the weight distribution bars. I do not believe that there is such a thing as too much jack. I also would not recommend anything less than a 2k pound capacity jack. The heavier your tow vehicle is the bigger capacity jack that you will need.
valhalla360
Mar 25, 2024Navigator
Agreed, lifting the back of the truck a bit to relieve stress on the bars is likely the bulk of the load but on the other hand, even the weaker jacks are rated for 3500lb, so not likely to be an issue. It's not like you want to lift the rear axle of the truck off the ground, just take a few inches from the springs.
