Preventing Repeat Of Frozen Water Hose
Arn
DW & I had an issue last week with our water freezing. There was about 3' of copper pipe coming out of the ground leading to the tap which froze, as did our 25' hose. I purchased a heat cable to prevent this from happening again. Instructions say not to use it with hose because there must be water in the line that the cable is attached to at all times but an RV supply hose always contains water. It also says not to let it touch the ground but if I tape foam pipe insulation around it I should be okay. I also plan to attach it to any exposed copper supply line as well as the tap. Wish me luck!
Arn
1958 Me
1963 Her
2015 Jayco Jay Flight 33RLDS
2020 Silverado LTZ Crew, 5.3 Max Trailering Pkg.
6 REPLIES 6
jerem0621
My dad camped in 15ยฐ degree weather and never unhooked his water and never had a problem...
What he did was get some foam pipe insulation...enough for the hose...he also got a rope light...wrapped the rope light around the hose and the faucet....then wrapped the hose and rope light I. The pipe insulation...he also used house hold faucet covers at the water inlet at the RV to keep it from freezing...he just left the rope light on all the time and it kept the hose or faucet from freezing.
Just what worked for him.
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
jeomelia
In freezing weather I only hook up the hose to fill the tanks, or use bottled water and pink stuff in the toliet.
1999 Dodge 2500 QuadCab Diesel
2005 Desert Fox 28KS
BrakeSmart
1992 Roadtrek Dodge Versatile
'...traveled the same road as many..."
Johno02
this will do it, use another heat tape for the faucet, tape to below ground level, and cover with foam insulation taped in place.
Heated water hose for RVs
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
WyoTraveler
Walmart sells aluminum tape. Actually metallic. I wrap the tape around my hose first then tape the heat tape to it. If you plan it ight you can have enough to put on the pipe also.Or buy a short one for yhat. I used to use aluminum foil on the hose until Walmart started carrying the tape.
time2roll
How about fill your fresh water tank just in case. Could even bring the hose in at night.
campingworld.com/freeze-ban-heated-drinking-water-hose
Still need heat tape for the faucet.
westend
Sounds like a good plan.
'03 F-250 4x4 CC
