Problem with my Superduty.
kydale
2011 Ford F-350 dually. 67k miles bought new. When I get in truck and go somewhere the "service engine indicator " is on. And stays on. Next time stays off. Dealership says fault code P204B Ran point test suspect Def pump. Pump test Ok. They suggested replacement of pump, 1200 bucks. But they aren't positive that is the problem.
Anyone else had anything similar?
21 REPLIES 21
4x4ord
I had a check engine light come on on my 2011, I can't remember the code but it was for the DEF tank heating element. I wired in a resister to mimic the blown heating element and it caused the check engine light to come on intermittently (I guess the resistance wasn't quite right). I ended up purchasing an entire DEF system from someone who deleted his new F450. The F450 has a different part number for the def tank but the only difference in the part was that the sensor for the low def indicator sensed a slightly higher level on the F450. Anyway it cost me $300 for the parts and I did the labor myself.
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
kydale
Doesn't seem to be using any more Def than normal. Truck runs like it always has. Service engine lite once on stays on till I shut engine off. Restart sometime it's on and sometimes not.
Grit_dog
Navigator
Navigator
Is it using def at the same rate it normally does?
When you clear the code, how long before it throws the code again?
Help see if it's a sporatic issue w the pump presuming that's what the code is for like you said.
Find a shop that knows what they're doing. Sounds like your dealer techs are parts throwers.
All else fails, if the reaper cost gets anywhere near what it cost to delete it, delete that sucker and enjoy a healthier truck. (If you're not in an emissions area)
kydale
I'm outside the five years.
SidecarFlip
donn0128 wrote:
Emission systems, arent they warranted for 100K miles?
Early 6.7L Fords had a lot of lift pump issues also.
Thought emissions components were 5/100?
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
donn0128
Colo_Native
I had my DEF injector replaced but I don't remember the code, but it did have service engine light on and would not stop ren unless I shut the truck down, mine was under warranty
2015 Winnebago Forza 34T
pushed by a 2011 Fusion Hybrid or 2020 Escape Hybrid
Retired DFD
