monacorw's avatar
monacorw
Problem with signal lights on tow vehicle
I was recently towing my 2012 Jeep GC and the connector cable disconnected at the RV and drug the ground resulting in a destroyed connector. I purchased a 7-pin to 6-pin Blue Ox cable and connected it. Everything works on the tow vehicle except the left signal/brake light. These work when I activate them in the Jeep so the bulbs are good. Does anyone have any idea what I might check?
  • Not sure if you have a separate fuse for each light. If you do, it's possible the fuse blew when the plug was dragging on the ground. It may have shorted out or grounded.
    S
  • There are no extra bulbs installed for towing, but I did find the problem. There was some corrosion on the pin at the jeep plug. I used a piece of Emory cloth to clean the pin and everything is working
  • A seperate bulb is installed in the taillight housing for towing. The taillight will have to be removed to check the bulb just as you would to replace the original bulb.
