Brockc
Jun 12, 2014Explorer
Problem with slide out mechanism/cables and chains
2006 Keystone Zeppelin. Since I have owned it, the cable buckles that connect the chains and cables have bumped or hit when passing during the opening or closing of the slide out. This has caused the system to hang, catch, and make noise as they release or pull apart. I have had to use sticks and bungy cords to stop them from hitting as they move through the process of opening/closing. Recently they hit again and the right side chain actually pulled out of the buckle. I spent two hours reconnecting the chain and buckles but now the slide will not close up evenly. I'm sure this is an adjustment issues. However, I now see that the mounting bracket that attaches the pulleys to the wall on the left side has actually pulled out of the wall. Any advice or experience with this type of issue would be greatly appreciated. Thanks
