Programmer
Mjsymank
I own a stock 2005 Dodge Ram 3500, automatic, 5.9 diesel. I am looking for a good programmer and a few of my friends like Mad Smarty Jr. Tuner.
My question is, What do think of this programmer? There is so many out there, not sure which one to chose.
14 REPLIES 14
Redwoodcamper
With his 05 you are correct. With newer trucks custom tunning affects tranny line pressure and shift points. Most of the canned tunners don't. So they can help preserve your tranny. With the 48re that he has, you are correct.
2011 ram 3500. Cummins 68rfe. EFI live. 276k miles and climbing.
2017 keystone bullet 204
Grit_dog
Navigator
Navigator
Agree, can't go wrong with custom tunes, IF they're setup right, but it's not like adding 100hp is easier on your trans coming out of a custom tune than it is from a "canned " tune. Custom tunes can be a bit more efficient though, but for half the price or less (compared to custom stuff + adding gauges, etc), nothing is wrong.
Plus, the good "canned " programmers have safety's built in to defuel if they sense tq converter or trans slip.
Redwoodcamper
For the most hp or even the best mpg custom tuning with an EFI live module is so far superior to of all the over the counter options. All of the above will help some, but isnt getting the best of anything. Call up anarchy diesel or Corry Willis at ppei and tell them what you have and what you want. The tunes have cooler egts and better mpg on the tow and eco settings, and way, way more hp on the race settings.
4x4ord
I put a tuner on my Duramax. It was incredible fun to drive till it took out the transmission.....about a week.
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
Wild_Card
Dont buyba canned tuner. Get one from a reputable tuner like Double R Diesel. Canned tunes are what hurts trucks.
2015 Ram 3500 Dually
Sundowner 2286GM Pro-Grade Toyhauler
djgodden
I use a Edge Evolution CTS and gained 50HP, 100 torque, and about 1 MPG in the economy mode.
2012 Ram 2500 4x4 Lariat Longhorn 6.7 CTD HO, Edge Evo CTS, Extreme Tow/Haul brakes, aFePower Diff cover, LL 5000 bags, 285/70R17, Reese Q20 w/slider. 2005 Montana 2955RL w/400w solar, Renogy MPPT, 4 x 6v @ 12VDC (450AH), 3000w Inverter, King VQ4100.
transamz9
Sinbadman5024 wrote:
We ran the Edge CS w/attitude on our 03. The reason I went with that one over the Smarty is because of the screen display. I can see what's going on and can makes changes on the screen as to what is monitored. I only ran it on 1 (econ) or 2(tow). If you don't get carried away with the tuner, your trans will last. I had the trans built because I have a friend who does them for me, inexpensively. We would average 14-15 mpg towing an 11,000 enclosed trailer.
I went with Bully Dog for the same reason. I like seeing what goes on. Also I like the fact that it de-tunes when it gets to preset parameters.
I towed on the tow tune for the first couple trips and then I just put it on the 140 hp tune and left it. Unlike fish, not all of us race our trucks just because they are fast. My ole truck is right at 100,000 miles and still running the factory 48 that everyone says is junk. Been towing way over the trucks capacity on the 140 hp tune for at least 50,000 of those miles.
2016 Ram 3500 Mega Cab Limited/2013 Ram 3500 SRW Cummins(sold)/2005 RAM 2500 Cummins/2011 Sandpiper 345 RET (sold) 2015 Sanibel 3601/2008 Nitro Z9 Mercury 250 PRO XS the best motor made.
Sinbadman5024
Shane, Ann, and Sebastian
2007 Volvo VNL 780 "Vlad"
2008 Dutchmen Grand Junction 34 QRL
Nicholsfamily05
We used a bullydog in our 2012 Ram 2500 5.7. We liked it added mileage to the tank and some good power.
We didn't go over board with the tune. Changed the shift points slightly and set it at moderate tune.
We pulled a 40' Bunkhouse with it and on our trips we could keep the truck at 10-11mpg.
We also did a cold air intake and we cut just the muffler out and welded in a 40 series flow master muffler.
Whenever the truck went into the shop they never gave us a hard time about the tuner and did all the warranty work.
2016 Ram 3500 4x4 Big Horn Crew Cab, SRW. Cummins Turbo Diesel Automatic 68RFE Trans
50 gallon diesel Transfer Flow tank with the Traxx 3 system.
2017 Sierra FLIK 5th Wheel
42' Front Livingroom, 15K
Hydraulic level up system
FishOnOne
Smarty...
With any added power be sure to budget some extra $$$$ to upgrade your torqueflight (48RE) auto transmission. ATS and Suncoast makes some nice upgraded transmissions.
Good luck...
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
Grit_dog
Navigator
Navigator
In order, for best tuners/programmers imo:
EFI live
Smarty/Jr
Edge
Bullydog
I have an old Bullydog on my 07. Came with the truck, been tuned since new. It ain't the cleanest one. Overfuels too much imo at low boost/high hp settings and it's easy for me to hit 14-1500 deg egts towing if I let er rip, but it has worked for 10 years now and adds plenty of power.
Bionic_Man
I had the Smarty JR on my 03. I really like the way it woke the truck up. With the tuner, my 03 would pull my boat and RV up the IKE faster than my '12 does.
As Scott suggested, I would add at least a pyro gauge. I had a 6 speed, so I wasn't worried about the transmission, but I would suggest you get a trans temp gauge. I never towed above level 2.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
Edd505
Can't speak to Dodge but I used an Edge Programmer, plugs into OBD port, on my F250, set to tow mode. It was like driving a different truck with no difference in mileage.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
ScottG
I did a lot of research before getting a SmJr. I had a powerMax PCMR or what ever it's called and it constantly threw codes. Finally ripped that expensive thing out and tossed it in the trash.
Since the Smarty has no hardware to connect, it doesn't junk up connections and have wires hanging all over the eng. It also maintains max. pressure levels set forth by Bosch so there is no unusual stress on the FI system. I've been pulling with it on the 100HP setting for several years and don't plan on changing. If there's a down side to this programmer, I haven't found it. Fuel efficiency didn't change even with the added power. No or very little extra smoke.
You will need to do some upgrades on your auto before using anything above the 30HP setting. I wold also at least install a pyro gauge.
