h45wt wrote:
Old-Biscuit wrote:
A FULL (80%) 20lb propane cylinder IS 4.7 gallons (20 divided by 4.2 equals 4.76)
20lb is where bleeder will spew 'liquid'...which is also where OPD shuts off filling
30lb...7.2 gal (80%)
I don't think you are correct about the 30lb tank. They are about 7 gal capacity so 80% would be 5.6 gals which is where my tanks shut off when filling.
One gallon of liquefied propane weighs 4.24 pounds.
Every DOT certified LPG tank (20 & 30 pounders, there are others, but for this thread we will discuss these) has a water capacity (WC) stamped on the collar of the tank. These tanks are certified to hold 80% of the stamped WC in liquefied propane.
Every manufacture of DOT LPG tanks has a WC number that their type of tank is certified to hold. These numbers may be different for different tank manufactures.
If a particular manufacture's tank has a WC of 25#s than at 80% full of propane, that would be 20#s of LPG. 25#s of water x 80% equals 20#s of LPG.
If a particular manufacture's tank has a WC of 38#s than at 80% full of propane, that would be 30.4#s LPG. 38#s of water x 80% equals 30.4#s of LPG.
Not many LPG dealers fill DOT 20# and 30# tanks by weight any longer. Most just fill until OPD valve shuts off the flow of LPG.
OPD valves are installed in tanks to deliver LPG to the 80% level of volume of WC stamped on the tank.
Sounds confusing, but is not. The amount of LPG put into different tanks can vary according to the certified WC stamped on the coller.
Lakeside
