colliehauler wrote:
I find it very interesting the recertification process that some of you described. My understanding for proper certification the cylinder needs to be inspected for damage/rust then filled with water and hydro tested. (Bringing the pressures up to more then operating pressure). Then if it passes stamping the new date on the cylinder for recertification. What some of you described is negligent and irresponsible.
It is not negligent or irresponsible. It has been done this way for decades by law in accordance with federal regulation.
There are 2 different recertifications allowed under federal regulations. One is the visual recertification you call negligent and irresponsible. The cylinder is inspected for excessive rust and pitting. The valve and the vent screw are also visually inspected. If deemed to pass inspection the cylinder is recertified for 5 years. When the first 5 year recertification is done an inspection number is stamped or etched on to the cylinder collar or an inspection sticker affixed to the cylinder collar with the number. The number has the letter E at the beginning or end. The second time the letter F is used. This type of inspection can only be done 2 times.
The other test is what you are describing which involves a hydrostatic pressure test. That test allows for the cylinder to be recertified for a longer period of time and the letter S is used in the recertification number added to the cylinder. I don't know how many times this recertification can be done.
