Deb_and_Ed_M's avatar
Deb_and_Ed_M
Jul 06, 2015
Putting a truck cap over Brophy tiedowns??
Next fall, Ed and I will be headed to our condo in Florida. We bought a used fiberglass truck cap, to carry some furniture to our condo.
I also want to carry another kayak down there - a 15' sit-on-top. I have a set of the foam blocks for a car roof that would work on the truck cap - but there's no way to tie down the boat with the cap.
I use Brophy bedrail clamp-on tie downs for my camper. THEY would give me tiedown points for the kayak!
Has anyone ever used a truck cap with the Brophy mounts? I figure I'd need some sort of spacer material between the mounts? I know I can get crossbars for a truck cap - but I hate to drill holes for a one-time-only trip, since I'll leave the kayak in FL permanently.
  • DWeikert wrote:
    Maybe this will give you some ideas?
    soft kayak roof rack
    Tie the kayak down on the truck cab instead of the bed cap?
    They say not to use the "strap around the roof" styles if you have side curtain air bags, which I do.....
  • DWeikert wrote:
    Could you tie the front and rear of the kayak to the front and rear bumper(trailer hitch?) instead of trying to come down the sides?
    Due to the length of the boat (15.5 feet) and price tag, I'd rather have it tied down at several points, plus locked with a bicycle cable. Ed says my universal crossbars will work on the topper, so I'll probably use those.
  • Thanks to you guys I got some ideas for carrying my kayak which is about 18' long and with outriggers. I want to put it on my toad, a soft top Samurai, and pull it behind the TC. Otherwise I have to pull the kayak trailer and leave the Sammie at home. Lots of measuring to do..
  • Could you tie the front and rear of the kayak to the front and rear bumper(trailer hitch?) instead of trying to come down the sides?
  • Jaxom wrote:
    As a one-time process, perhaps you could put flat weatherstripping between the truck cap and the bed rails???
    I was thinking maybe some vinyl trim or ripped-down thin plywood? Something the same thickness as the Brophys, so the cap is sitting on a uniform surface? Once we get the kayak to Florida, we can redo the cap so it's a "normal" installation.
  • As a one-time process, perhaps you could put flat weatherstripping between the truck cap and the bed rails???
