Question about brake controller
robwhite61
I just checked my pins on my brake connector and was getting 12 volts all the time on trailer brake pin (with or without controller or brakes activated). I had a problem with my breakaway switch - could this be causing this problem? My TV is a 2001 F350 DRW.
2001 Ford F-350 DRW, 7.3L Turbo Charged
2013 Heartland Prowler 31 PRET
4 REPLIES 4
Turtle_n_Peeps
Me Again wrote:
Pulling the emergency brake cable can sometimes can take out the vehicle controller according to warnings. Chris
X2, more than likely just the controller.
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
Me_Again
robwhite61
Trailer is not connected at this time. Another part of my problem is when my trailer (2013 Heartland Prowler 31 P RET)is hooked up, my trailer brakes are inop with my controller not showing anything on the display. I probably burnt up the brakes, but hoping beyond hope I have only ruined the controller. One controller is cheaper than 4 brakes (and easier to change). My problem was caused by me doing something stupid. I'll just leave that part at that. :S
ScottG
If the break away switch is engaged then there will be 12V on the brake line.
So were you getting 12V on two pins?
With the brake controller disconnected:
You should get 12V on 1 pin
Ground on 1 pin
12v Signal on one pin when the brake is depressed
Nothing on the wire going to the trailer brakes
