prginocx
Sep 04, 2020Explorer
Question about my on-demand water pump and ?
So I've got a '96 Pastime Cabover 8' long. My daughter left the switch on for the water pump, it was humming away this morning when I got out to the camper. So lets say it was on all night. There was water in the tank. It still seems to work 5 hours later after turning it off and letting it cool down.
Do you think there is any permanent damage ? Should I replace the pump ?
2nd topic: One of my lift jacks is a bit slower than the other three, it is noticeable when you are unloading / loading the camper, you have to run it a bit longer to keep level going up/down. My set up has electric motors on each corner, with dual switches. Two switches in rear left side, two switches front left side. so to raise / lower, you walk back and forth a bit. I'm wondering if this slower motor is the first signs of it wearing out ?
