Apr-22-2014 10:36 PM
Apr-24-2014 06:40 PM
Apr-23-2014 08:55 PM
Dtaylor wrote:
If it is under warranty, take it back to the dealer or call the manufacturer. Many times the manufacturer will tell you how to fix or send you the material to fix it yourself and avoid going to the dealer. (assuming you are able to make the repair yourself)
Apr-23-2014 08:53 PM
wmoses wrote:fatboy66 wrote:
I thought he asked about how to make a glue repair.
Re-read the question to see what he was asking ... you should see two questions. 😉 Then, if you think a little on it, you might also surmise what is going through his mind - IOW read between the lines.
Apr-23-2014 07:27 PM
Apr-23-2014 06:02 PM
Apr-23-2014 04:41 PM
wmoses wrote:josh1231 wrote:
I am a newbie to both this message board, and travel trailers in general. I recently purchased a Solaire Ultralite and 2 pieces of the trim between the seams of the wall panels has become unglued, and "popped" out. Is this a normal happening on a new TT, or should this concern me? Also, should I glue this back into place myself, and if so what should I use to glue it, and if not should I take it to the dealer? Any help would be greatly appreciated because as I mentioned, I know very little, but am trying to learn.
Thanks in advance.
Josh - any photos? Also - welcome to the forum and to TT RVing. 🙂
For something like this you would probably want to think 100 times before taking it to the dealer. Not worth the hassle. Reserve those trips only for the big issues like roof or slideout problems and appliance issues.
Panels becoming unglued is a result of shoddy workmanship and that is a regular occurrence with these RVs, as the QA is weak in the industry and the units are put together by humans on a tight schedule where the almighty dollar calls the shots. This is one of many fixes you will have to do yourself regardless of whether there is a warranty in effect.
Apr-23-2014 06:16 AM
Apr-23-2014 04:57 AM
Thanks in advance.
Apr-23-2014 12:16 AM
